When i install RST 16.0.2.1086
It's install not Intel (R) 200 Serives Chipset Family SATA ACHI controler driver , but installing Intel (R) 300 Serives Chipset Family SATA ACHI controler
when i try figurate why, i find this
Device Name:Intel(R) 200 Series Chipset Family SATA AHCI Controller
Hardware ID:PCI\VEN_8086&DEV_A282&SUBSYS_B0051458&REV_00
PCI\VEN_8086&DEV_A282&CC_010601
PCI\VEN_8086&DEV_A282&CC_0106 <---- Device ID matches with our database
Compatible ID:
PCI\VEN_8086&DEV_A282&REV_00
PCI\VEN_8086&CC_010601
PCI\VEN_8086
PCI\CC_010601
PCI\CC_0106
Intel(R) 300 Series Chipset Family SATA AHCI Controller drivers / System manufacturer System Product Name
Device Name:Intel(R) 300 Series Chipset Family SATA AHCI Controller
Hardware ID:PCI\VEN_8086&DEV_A282&SUBSYS_873C1043&REV_00
Compatible IDs:
PCI\VEN_8086
PCI\CC_010601
PCI\CC_0106
so what to do for it install correct driver ?
Hello mraksoll
Thank you for joining this Community.
I understand that you are experiencing issues when installing our Intel® Rapid Storage Technology driver.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As well can you please tell us the reason why is Intel® Rapid Storage Technology being installed on your system?
What is your main goal when installing the driver?
I hope this helps,
Diego S.
Hello mraksoll
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
