Rapid Storage Technology
Intel® RST, RAID
2178 Discussions
iRST 11.6, Windows 8 x64, RAID1. Disk marked as "Verify" during reboot
I see this strange behavior after installing iRST 11.6 on Windows 8 Pro x64.
My storage is built up of two SATA HDDs in RAID1 configuration, and when I reboot my system, the RAID array is always maked as "Verify" without any suitable reason.
I must wait for the complete verification of the array before starting to work, unless I click on "Cancel" (guessing that my array isn't really corrupted).
Is this a bug in the iRST package/iastorV.sys driver?
Is there a way to solve this?
Alberto
Italy
DArce
Valued Contributor III
Please provide the full System Configuration being used. Additionally please copy-paste the system report generated by Intel® Rapid Storage Technology.
The instructions on how to get this report are available on this article:
http://www.intel.com/support/chipsets/imsm/sb/CS-023487.htm http://www.intel.com/support/chipsets/imsm/sb/CS-023487.htm
Hello Diego.
Here's my system report:
System Report
System Information
OS name: Microsoft Windows 8 Pro with Media Center
OS version: 6.2.9200 9200
System name: pcname
System manufacturer: Gigabyte Technology Co., Ltd.
System model: P35-DS3R
Processor: GenuineIntel Intel64 Family 6 Model 15 Stepping 11 2,333 GHz
BIOS: Award Software International, Inc., F13
Intel® Rapid Storage Technology enterprise Information
Kit installed: 11.6.0.1030
User interface version: 11.6.0.1030
Language: Italian (Italy)
RAID option ROM version: 7.5.0.1017
Driver version: 11.6.0.1030
ISDI version: 11.6.0.1030
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 3 MB
Number of volumes: 1
Volume member: SYSTEM-RAID1
Number of array disks: 2
Array disk: WD-WCARW0019515
Array disk: WD-WCARW0333145
Disk data cache: Enabled
Volume name: SYSTEM-RAID1
Type: RAID 1
System volume: Yes
Data stripe size: 64 KB
Write-back cache: Enabled
Initialized: Yes
Parity errors: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Hardware Information
Controller name: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Type: SATA
Mode: RAID
Number of SATA ports: 6
Volume: SYSTEM-RAID1
Number of spares: 0
Number of available disks: 0
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 10274
Product revision: 2
Direct attached disk: WD-WCARW0019515
Direct attached disk: WD-WCARW0333145
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Array disk
System disk: No
Command queuing: NCQ
SATA transfer rate: 3 Gb/s
Model: WDC WD3200AAKS-00VYA0
Serial number: WD-WCARW0019515
SCSI device ID: 0
Firmware: 12.01B02
Disk on Controller 0, Port 1
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: WD-WCARW0333145
SCSI device ID: 1
Firmware: 12.01B02
ATAPI device on Controller 0, Port 5
SATA transfer rate: 1,5 Gb/s
Model: TSSTcorp DVD-ROM SH-D163B
Serial number: &# 144;ë
Firmware: SB04
Empty port
Port: 2
Port location: Internal
Empty port
Port: 3
Empty port
Port: 4
If you need further informations, let me know.
Alberto,
Italy
DArce
As per the information you provided the option ROM (control I menu you see when the system boots during POST) in your system is using version 7.5.0.1017 which is quite out to date, and could be related to this behavior.
I suggest that you check with your motherboard manufacturer for an updated version of this, which is usually updated through a BIOS update.
Hello, and thanks for your answer.
Unfortunately, the manufacturer hasn't been releasing a new BIOS version for my motherboard since 2009.
I already contacted them for another kind of issue, but I got no answer.
Do you think there's another way to solve that?
Unfortunately, it seems that version 11.2 of iRST 11.2 isn't Windows 8 compatible.
TMasa5
I have the exact same problem with my configuration using latest drivers in Windows 8 x64, but Windows 7 x64 works fine.
Here is my configuration:
System Report
System Information
OS name: Microsoft Windows 7 Ultimate
OS version: 6.1.7601 Service Pack 1 7601
System name: BELLDANDY
System model: To be filled by O.E.M.
Processor: GenuineIntel Intel64 Family 6 Model 45 Stepping 7 3.801 GHz
BIOS: American Megatrends Inc., F13p
User interface version: 3.5.0.1092
Language: English (United States)
Intel controller: SATA (AHCI)
RAID option ROM version: 3.5.0.1005
Driver version: 3.5.0.1092
ISDI version: 3.5.0.1092
RAID Configuration
Available space: 286,150 MB
Volume member: Volume0
Array disk: Z1F1QRSV
Array disk: Z1F1QSVD
Array Name: SATA_Array_0001
Available space: 190,790 MB
Volume member: Volume1
Number of array disks: 4
Array disk: 9TE151NA
Array disk: 5QJ0C5HM
Array disk: 5QJ0C5JG
Array disk: WD-WCASJ0049561
Volume name: Volume0
Status: Normal
Type: RAID 1
System volume: No
Initialized: Yes
Parity errors: 0
Physical sector size: 4096 Bytes
Volume name: Volume1
Status: Normal
Type: RAID 5
System volume: No
Initialized: Yes
Parity errors: 1
Controller name: Intel(R) C600 series chipset SATA RAID Controller
Type: SATA
Mode: RAID
Number of volumes: 2
Volume: Volume0
Volume: Volume1
Number of spares: 0
Rebuild on Hot Insert: Disabled
Manufacturer: 32902
Model number: 10278
Product revision: 5
Direct attached disk: Z1F1QRSV
Direct attached disk: Z1F1QSVD
Direct attached disk: 9TE151NA
Direct attached disk: 5QJ0C5HM
Direct attached disk: 5QJ0C5JG
Direct attached disk: WD-WCASJ0049561
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST3000DM001-1CH166
Serial number: Z1F1QRSV
SCSI device ID: 0
Firmware: CC24
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: Z1F1QSVD
SCSI device ID: 1
Firmware: CC24
Disk on Controller 0, Port 2
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST31000333AS
Serial number: 9TE151NA
SCSI device ID: 2
Firmware: CC1F
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST31000340AS
Serial number: 5QJ0C5HM
SCSI device ID: 3
Firmware: SD15
Disk on Controller 0, Port 4
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST31000340AS
Serial number: 5QJ0C5JG
SCSI device ID: 4
Firmware: SD15
Disk on Controller 0, Port 5
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: WDC WD10EACS-00ZJB0
Serial number: WD-WCASJ0049561
SCSI device ID: 5
Firmware: 01.01B01
TMasa5
I tried the those drivers and it seems better, but sometimes still gets into verify mode upon restarting the pc. Also noticed that the raid array verify progress gets reset to 0% after restarting as well.
