Rapid Storage Technology
Intel® RST, RAID
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
1866 Discussions
iRST driver (17.7.0.1006) unstable ... BSOD caused by iaStorAC.sys?
dmuso1
This latest iRST driver (17.7.0.1006) seems unstable with my RAID 0 configuration. When I run disk repair utilities on my SSD array such as HD Sentinel PRO and Chkdsk, I get the BSOD about half-way through the scanning process! It says "iaStorAC.sys" failed with a stopcode of SYSTEM_THREAD_EXCEPTION_NOT_HANDLED ( see attachment). I use two (2) 500GB Samsung 950 PRO SSDs to create a 1TB RAID 0 array.
I have no problems with the default windows iRST version 15.44.xxx but its slow compared to version 17.xx. What should I do to fix the BSOD issue?
PS
I'm not sure if this is related but I started to notice the BSOD after I performed a FW upgrade on my SSDs the day before. Not sure if these two events are connected but I doubt it since the Samsung SSD FW has been out for a couple of years.
Leonardo_C_Intel
Hello dmuso1
Thank you for posting in the Intel Community.
I would like to have more information about your system configuration. please provide me with the following reports:
·        Provide the Intel® System Support Utility for Windows* (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-) report.
·        Provide the System Reports for Intel® Rapid Storage Technology (https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html)
NOTE: completing the firmware update on the SSD has to be done without having the disk on a RAID structure since you mentioned that you have a RAID 0 you will have to back up the data, destroy the RAID, complete the firmware update then rebuild the RAID and copy the data back.
Leonardo C.
A Contingent Worker at Intel
dmuso1
Thank you Leo for responding and I've attached the files you've requested...
First of all, I reverted to the previous driver, version 17.5.2.1041 and everything works fine as I had expected. Disk utilities work just fine with no issues and no more BSOD issues. I checked the release date of the latest driver 17.7.1.1006(?) and it was Dec 28th, 2019. It seems (to me) that it was a rush job, not completely tested but had to be released before years end, for some reason? When I reverted to the 17.5 version, I was informed that I would be replacing a newer files (iaStorAC.sys/ini/.xxx) with an older one for the 17.5 version. It was the only file that generated that message, so it seems all other files between 17.5 and 17.7 are identical, except those that belong to iaStorAC.xxx drivers.
Secondly, when I updated the SSD firmware, I disabled the raid array in BIOS and used the AHCI mode. I had a bootable thumb drive with the updated firmware and the update was done in two steps, one for each 500GB SSD drive. Afterward, I re-enabled the raid array and booted normally and all was ok. No more BSED issues when I run various drive scan and repair utilities. With version 17.7, they all crashed with the BSOD around the 50% - 52% scan/repair point, right where I had several bad and unreadable drive sectors. Now, all are repaired with iRST version 17.5 . I would like to install 17.7 once its fixed, but these public FW releases just before year-end are suspect and not advisable.
Thirdly, I'm only able to attach 1 file at a time(?).
Thank you for your time!
David Musoke
iRST_System Report below:
System Report
System Information
OS name: Microsoft Windows 10 Pro
OS version: 10.0.18363
System name: DESKTOP-0S95Q5J
System manufacturer: Micro-Star International Co., Ltd.
System model: WT72 6QL
Processor: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 2.601 GHz
BIOS: American Megatrends Inc., E1782IWS.121
PCH: 0xA150
Intel® Rapid Storage Technology enterprise Information
Kit installed: 17.5.2.1041
User interface version: 17.5.2.1041
Language: English (United States)
RAID option ROM version: 14.6.0.2285
Driver version: 17.5.2.1024
ISDI version: 17.5.2.1041
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 3 MB
Number of volumes: 1
Volume member: Intel SSD 950PRO
Number of array disks: 2
Array disk: 0025_3853_61B0_1A3E.
Array disk: 0025_3853_61B0_1A25.
Disk data cache: Enabled
Volume name: Intel SSD 950PRO
Status: Normal
Type: RAID 0
System volume: Yes
Data stripe size: 16 KB
Write-back cache: Off
Parity errors: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller \\Scsi0
Type: SATA
Mode: RAID
Number of SATA ports: 6
Volume: Intel SSD 950PRO
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Enabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 49
Direct attached disk: W77232PX
Direct attached disk: 0025_3853_61B0_1A3E.
Direct attached disk: 0025_3853_61B0_1A25.
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Available
System disk: No
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: ST1000LM014-1EJ164
Serial number: W77232PX
SCSI device ID: 0
Firmware: SM36
Physical sector size: 4096 Bytes
Disk on Controller 1, Port 0
Status: Normal
Type: PCIe SSD
Usage: Array disk
System disk: No
Port interface: NVMe
PCIe link speed: 4000 MB/s
PCIe link width: x4
Model: Samsung SSD 950 PRO 512GB
Serial number: 0025_3853_61B0_1A3E.
SCSI device ID: 1
Firmware: 2B0QBXX7
Disk on Controller 3, Port 0
Status: Normal
Type: PCIe SSD
Usage: Array disk
System disk: No
PCIe link width: x4
Serial number: 0025_3853_61B0_1A25.
SCSI device ID: 3
Firmware: 2B0QBXX7
ATAPI device on Controller 0, Port 2
Transfer rate: 1.5 Gb/s
Model: HL-DT-ST BD-RE BU20N
Serial number: MD8FALA2147
Firmware: 1.00
Empty port
Port: 0
Port location: Internal
Empty port
Port: 1
Leonardo_C_Intel
Hello dmuso1
I was checking the details that you have provided, fist I would like to thank you for the clarification of the steps that you have taken to complete the firmware update on the SSD, in addition, based on your system details/specifications you are using a chipset from the Intel® C230 Series Chipsets that is a server intended chipset on an MSI* workstation we recommend referring the issue with MSI* support If it is needed MSI will work the behavior directly with Intel.
Leonardo C.
dmuso1
Hi Leo … thanks for responding
Now to your statement about using a server-based chipset in a laptop such as mine …. First of all, it would be virtually impossible for such a chipset to run on my laptop due to the chipsets extreme power requirements that do not fit within the laptops power budget. MSI has been designing millions of top-notch laptops with the C236 chipset since its first introduction in Q1 2015. The C236 is a mobile chipset for the Skylake family of processors, which my laptop has.
Secondly, I believe there's been a mix-up regarding chipsets. The C230 series family of chipsets you alluded to earlier is not a storage controller chipset that handles RAID operations. RAID tasks belong to the Intel SATA/PCIe RST Premium Controller chipset, which uses the buggy firmware in question. According to Device Manager, the C230 series uses completely different driver firmware (10.1.1.45) than the iRST Premium Controller chipset for raid that uses the buggy firmware in question (17.7.0.1006).
I hope that clears up the confusion about chipsets used in my system. I'd still want a permanent solution to my original problem. As per the BSOD, the problem lies in the latest version of the iaStorAC.xxx driver.
David Musoke
Leonardo_C_Intel
Hello dmuso1
Thank you for waiting.
Did you download Intel® RST for Intel® download center side? (Reference link: https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST-)
Can you provide us with the BSOD dumb flog file? This link might help: https://social.technet.microsoft.com/Forums/windows/en-US/684d77b8-0257-426e-a363-54fa54c64a3e/locat...
Please be aware that the content on that site is not controlled by Intel®. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
Leonardo C.
dmuso1
Thanks for the response Leo:
A) Yes, I download all my iRST executables from the Intel site you linked to. I cannot afford to get them elsewhere. Also, I use the Intel Driver Support & Assistant utility tool which boots up on windows startup to search for new drivers daily and download them accordingly.
B) As for the windows dumb files, none existed on my drive since I had set the windows pagefile size to zero. So all dumb files were stored in volatile RAM which erased them on bootup. I re-installed the buggy version 17.7 and I set the pagefile setting to Auto, so that windows manages my pagefile. I rerun chkdsk /f /r for bad sector repair, if it found any. There was no BSOD seen this time around, which was confirmed with other disk repair utilities I used. I had no bad sectors as they were repaired under the earlier version 17.5 driver, which I've now been running for a about a week.
I repeated the chkdsk test again, this time with the Pagefile setting back to zero, as I had it originally when I observed the BSOD errors with the 17.7 driver and re-run all my disk repair tests. No BSOD screens observed, which was a relief. So, I came to the following conclusion.
  1. The Pagefile setting (none or Auto) has nothing to do with the observed BSOD issues.
  2. The 17.7 definitely driver fails if there bad sectors on the drive that are in process of being repaired as observed before. The problem is in the iaStorAC.xxx driver(s) as indicated by the original BSOD graphic.
As you may imagine, I'm not about to cripple my main SSD drive to simulate a bad sector and attempt a repair under version 17.7. I hope you understand.
David
Leonardo_C_Intel
Hello dmuso1
Thank you for the response let me look into the details that you have shared. I will be posting back as soon as possible.
Leonardo C.
Leonardo_C_Intel
Hello dmuso1
This behavior has been forwarded to engineering and tests are being conducted and any issues will be ironed out in the next release in the meantime:
·        Can you roll back the Samsung SSD FW and see if the issue still occurs?
·        Also, was it working fine with before updating the SSD FW on 17.7 drivers?
Leonardo C.
dmuso1
Hi Leo:
  1. I cannot roll back to the old firmware, since it no longer exists on Samsun's site. This FW was released in mid-2015 or early 2016. I was just lazy and didn't upgrade my NVM. If it was buggy, there'd be lots of bug reports online with this BSOD issue. Its not difficult to emulate if you had a faulty NVM with bad sectors... and Samsung would receive lots of grief over it. Its new FW has been stable for over 4 years.
  2. I don't really know as I upgraded the NVMs first then the 17.7 drivers later (2 to 3 days later), after the Intel upgrade tool told me so.
But the problem doesn't exist in 17.5 drivers since I managed to successfully repair the NVMs with their new FW on your 17.5 drivers. This was not possible with the 17.7 drivers as first noted, so the problem tracked the Intel driver.
Thanks for all the help in tracking down this problem. I appreciate the hard work!
David
Leonardo_C_Intel
Hello dmuso1
Thank you for your prompt response, Allow me to keep looking into this information, I will be posting back as soon as I have news.
Leonardo C.
Leonardo_C_Intel
Hello dmuso1
Thank you for waiting and for sharing this behavior, as motioned previously we are working on the next release for Intel® RST, we recommend monitoring the Intel® download center and testing the new Intel® RST version when released, in the meantime, we are going to proceed to closed the thread, but if you have further questions please contact us back.
Hope this helps
Leonardo C.
dmuso1
Leo ... thank you for your patience and understanding regarding this BSOD issue with version 17.7 drivers. I hope to never get another bad-disk-sector related BSOD on my computer ever but hope that should that unfortunate event happen, versions 17.8 and beyond will be able to allow me fix the problem using my disk repair tools without crashing the computer. Look forwards to versions 17.8 and beyond.
What would really help me is to find out if the development team verifies the problem in their 17.7 code. There has to be some unexpected exception problem in the current 17.7 code that occurs when accessing or reading/writing to bad sector sectors. Would you be able to let me know if that's the case?
Thank you!
-David
Leonardo_C_Intel
Hello dmuso1
No, unfortunately, customer support does not have access to the engineering details and the information is not public.
Leonardo C.
