Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
my hdd invisible, how can online it without losing my personal data
vgoud
System Report
System Information
OS name: Microsoft Windows 10 Home Single Language
OS version: 10.0.18362
System name: LAPTOP-H17MG80C
System manufacturer: Acer
System model: Predator PH315-51
Processor: GenuineIntel Intel64 Family 6 Model 158 Stepping 10 2.304 GHz
BIOS: Insyde Corp., V1.26
PCH: 0xA30D
Intel® Rapid Storage Technology enterprise Information
Kit installed: 16.7.8.1024
User interface version: 16.7.8.1024
Language: English (United States)
Driver version: 16.7.8.1024
ISDI version: 16.7.8.1024
Storage System Information
Controller name: Unknown Controller \\Scsi0
Type: SATA
Mode: AHCI
Number of SATA ports: 2
Number of volumes: 1
Volume: Volume_0000
Number of spares: 0
Number of available disks: 0
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0xA353
Product revision: 16
Direct attached disk: 50026B7682DCF4BE
Direct attached disk: WD-WXE1A19L4309
Disk on Controller 0, Port 1
Status: Normal
Type: SATA SSD
Location type: Internal
System disk: No
Disk data cache: Enabled
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: KINGSTON RBUSNS8180DS3128GJ
Serial number: 50026B7682DCF4BE
SCSI device ID: 0
Firmware: SBFK61E1
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 4
Status: Offline
Type: SATA disk
System disk: No
Model: WDC WD10SPZX-21Z10T0
Serial number: WD-WXE1A19L4309
SCSI device ID: 0
Firmware: 02.01A02
Physical sector size: 4096 Bytes
David_V_Intel
Hello vgoud,
Thank you for posting on the Intel ® communities.
When did you install Intel ® Rapid Storage Technology? Do you have any RAID set up? When did the drive become "invisible"? These questions are important to determine the cause of this behavior.
If you do have a RAID, please provide me with the configuration, is it a RAID 1, RAID 0, RAID 5?
Please let me know so I can assist you further.
David V
A Contingent Worker at Intel
David_V_Intel
Hello vgoud,
Please provide me with answers to the questions posted previously.
Let me know if you need more assistance.
David V
vgoud
vgoud
it comes with laptop,i didn't istalled.
i done raid setup.and it is raid 1.after completion raid set it became invisibleScreenshot (7).pngScreenshot (6).pngScreenshot (5).png
vgoud
System Report
System Information
PCH: 0xA30D
Kit installed: 17.0.0.1072
User interface version: 17.0.0.1072
RAID option ROM version: 16.0.2.3402
Driver version: 17.7.0.1006
ISDI version: 17.0.0.1072
RAID Configuration
Array Name: SATA_Array_0000
Available space: 3 MB
Volume member: Volume_1
Number of array disks: 2
Array disk: 50026B7682DCF4BE
Array disk: WD-WXE1A19L4309
Volume name: Volume_1
Status: Normal
Type: Recovery
Update mode: On request
System volume: Yes
Data stripe size: 64 KB
Write-back cache: Write back
Initialized: Yes
Parity errors: 0
Blocks with media errors: 0
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller \\Scsi0
Type: SATA
Mode: RAID
Volume: Volume_1
Number of spares: 0
Model number: 0x282A
Status: Normal
Type: SATA SSD
Usage: Master disk
System disk: No
SCSI device ID: 0
Firmware: SBFK61E1
Status: Offline
Type: SATA disk
Usage: Recovery disk
System disk: No
SCSI device ID: 0
Firmware: 02.01A02
David_V_Intel
Hello vgoud,
Thank you for your response.
I was reviewing the system report you have posted and I can see that there is a 1TB drive labeled as "Recovery Disk", the model shown is "WD10SPZX-21Z10T0".
If this is not the disk then it is advised to check under "Disk Management" to see if the disk shows at all or if it is recognized by the O.S.
When you are first setting up Intel ® Rapid Storage Technology, the software offers an option to set a drive as a recovery, which appears to be the case of what happened here, if you would like to remove the recovery disk then you can refer to the options below:
A. Using the Intel® Rapid Storage Technology User Interface Utility
1.Run the Intel® Rapid Storage Technology UI from the following Start menu link:
Start -> All Programs -> Intel® Rapid Storage Technology -> Intel® Rapid Storage Technology UI
2.Under ‘Status’ or ‘Manage’, click on the volume you want to delete. You will be presented with the volume properties on the left.
3.Click on ‘Delete volume’
4.Review the warning message and click ‘Yes’ to delete the volume.
5.The ‘Status’ page refreshes and displays the resulting available space in the storage system view.
B. Using the Option ROM User Interface
1.During POST, use CTRL-I to enter the RST BIOS Extension.
2.Mark the drive as "Non-RAID".
3.Reboot your system.
*NOTE: Keep in mind that the data is no longer there when the disk is a recovery disk.
David V
AndrewG_Intel
Hello vgoud,
I was checking this thread and would like to know if you were able to check the information and steps provided in the previous post. If so, could you please share the outcome?
Andrew G.
AndrewG_Intel
Hello vgoud,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Andrew G.
