Bij het installeren van de rapid storage technology op een HP 6300 SFF krijg ik deze foutmelding. Ik heb het gehele register nagezocht op vermeldingen van de Rapid Store en niets gevonden. Ook in autorun is niets te vinden. Hoe kom ik van deze melding af. OS Windows 10 april update.
Hello
Thank you for joining the community.
After translating your post I see that you are having problems with Intel® RST, in order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
What is the version of Intel® RST that you are installing?
Was your system working properly with Intel® RST or this is the first time you install the software?
Leonardo C.
Hallo,
The was system working properly with Intel® RST . The problem occured after the update of the Windows 10 update,
The version
Filename: iaAHCIC.inf
; ** Revision: 03/25/2014,12.9.3.1000
; ** Abstract: Windows* INF File for AHCI Intel(R) Rapid Storage Technology Driver
; ** Installs: RST AHCI Controller Miniport
Gé Blijleven
Hello gkblijleven
Thank you for your response.
I am looking into your system report I see that your system has an Intel(R) 7 Series/C216, I case of Intel® RST for Windows® 10 does not support the chipset on your system. if you require the use of Intel® RST I recommend to install as a supported operating system by HP.
Leonardo C.
