Rapid Storage Technology
Intel® RST, RAID
the latest version of RST
Joyce77
Regarding the version 18.1.6.1039 of RST, could you help to confirm if optane can provide cache for Raid0 acceleration?since this version can provide the maintenance of RAID 0/1/5/10 according to the description you provided.
Look forward to your reply.
David_G_Intel
Hello Joyce77
Thank you for posting on the Intel️® communities. To provide provide the most accurate response we need more information on your current setup, please share with us the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
David_G_Intel
David G.
David_G_Intel
David G.
