Community
cancel
Showing results for
Search instead for
Did you mean:
drMikeT
Re: Re:Vtune analyzer (2020.02) does not display the working tabs
Jump to solution
Hi Arun, thanks for the response.
I tried to install the latest OneAPI Base toolkit over the web but the local installer (l_BaseKit_p_2021.2.0.2883_offline.sh) claims that the MKL component is corrupted and it stops proceeding...
I tried using the CLI of the installer but it also hangs with ERROR "Cannot create directory"
Can U let me know how to install locally OneAPI components using Python? I'd like to get both Base and HPC toolkits.
BTW, has the "classic" Parallel Cluster Studio XE been discontinued?
The target is Linux CentOS Linux release 7.9.2009 (Core)
thanks
Michael
ArpanB_Intel
Hi Michael, please visit this link> https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-onea..., for guidance on how to install the Intel® oneAPI Base Toolkit with Command Line.
ArpanB_Intel
Hi Michael, it is true. Intel® Parallel Studio XE has now been discontinued and transitioned on to Intel® oneAPI.
Coming to your query, if you encounter a corrupted web installer message, we suggest you to download the local installer and try again. Installations using a local installer are much more stable as compared to a web installer. Also, please check whether you have the permissions to create a directory or to write a file to the selected directory.
drMikeT
Thanks for the response!
Can you provide if possible the command line steps to install through the local installer CLI? Using the GUI hides details that may be important to resolve this. I have downloaded the local installer again but I am hitting the same problem, while using the GUI. I do have access to the destination directory.
Note that I am running this behind our company's firewall in case the installer is trying to download updates or other components.
Michael
ArpanB_Intel
