Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, and RAID Storage.
5016 Discussions
Дайте пожалуйста БИОС для матeринская плaтa DН57JG
Геннадий
Не могу найти БИОС для программатора
Геннадий
n_scott_pearson
I have attached the final BIOS. This should be installed using the jumper-based BIOS Recovery process.
Intel provided BIOS releases in .BIO file format. They specifically did not provide BIOS releases in formats compatible with flash programmers as this was insecure. If your board is not capable of operating in the BIOS Recovery mode, then you are out of luck.
