Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4548 Discussions
Материнская плата s2600KPF не могу настроить SOL
ВСоло
собственно вот
[root@head~]# ipmitool -H X.X.X.X -U ADMIN sol info 1
Password:
Info: SOL parameter 'Nonvolatile Bitrate (5)' not supported
Info: SOL parameter 'Volatile Bitrate (6)' not supported
Set in progress : set-complete
Enabled : true
Force Encryption : false
Force Authentication : false
Privilege Level : USER
Character Accumulate Level (ms) : 60
Character Send Threshold : 96
Retry Count : 7
Retry Interval (ms) : 500
Volatile Bit Rate (kbps) : IPMI-Over-Serial-Setting
Non-Volatile Bit Rate (kbps) : IPMI-Over-Serial-Setting
Payload Channel : 1 (0x01)
Payload Port : 623
Пользователь ADMIN является администратором в ipmi.
[root@node01 ~]# ipmitool -H node01-ipmi -U ADMIN sol set non-volatile-bit-rate 57.6
Password:
Error setting SOL parameter 'non-volatile-bit-rate': Parameter not supported
подскажите где проблема.
In order to further assist you with your request we would like to know the following:
Is this a new configuration or was working before?
Can you provide us the full model of this board?
In addition, please make sure that you are using the latest firmware.
ВСоло
The configuration of the new.
Product Name: S2600KPF
Part/Model Number: G93685-351
I do not use the latest firmware, firmware update may solve the problem?
We recommend updating the firmware since that would be the next course of action. Try to schedule downtime and let us know the results.
David_A_Intel
bkmz Were you able to solve this by updating the firmware? Feel free to let us know if you need anything else.
Dave A.
