Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4617 Discussions
Сервер на основе SE7520BD2.
dshma
Здравствуйте. у меня тоже сервер на такой плате. перестал включаться. у одного блока питания желтая лампочка. у 2го- зеленая. при включении кнопки включения - происходит бип 1-5-4-4. даже если вынимаю "желтый" БП - все тоже самое происходит.
Thank you for contacting Intel Customer Support.
I would like to help you with your issue. Could you please elaborate in English, so we can better assist you?
Thank you in advance.
faugub_intel # iwork4intel
dshma
Hello!
Where i can get Power Supply for this motheboard? Or which analogues are there?
We regret to inform that the Intel Server Board SE7520BD2 is currently in End of Interactive Support (EOIS). This means that Intel no longer provides interactive support for this service via telephone, e-mail, chat, or other tools. Technical articles will continue to be available on the Intel Support website.
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/se7520bd2/sb/c51518007_se7520bd2_userguide.pdf Power Supply:
The minimum power supply required depends on the server chassis into which the server board is installed. Your supply must provide a minimum of 1.2 A of 5 V standby current or the board will not boot. &# 131;
  • For the Intel Entry Server Chassis SC5295-E DP, a minimum 450W power supply is required. &# 131;
  • For the Intel Entry Server Chassis SC5295-E BRP, a minimum 500W power supply is required. &# 131;
  • For the Intel Entry Server Chassis SC5300, a minimum 600W power supply is required. &# 131;
  • For the Intel Entry Server Chassis SC5275-E, a minimum 600W power supply is required.
Use the power budget tool to determine the minimum power supply for your system, based on all installed components.
For Technology Providers, http://locate.intel.com/ click here.
dshma
The original power supply (delta dps-730) has a cable AUX SIG. Whether it is obligatory?
If the motherboard does not have the option, it is not mandatory. It is always recommended to try using validated parts.
For future reference, please check the document attached. It is the Technical Product Specification.
