Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Сan't install drivers on Hyper-V Server 2012 r2...
Jump to solution
Hi!
I have installed Hyper-V Server 2012 r2 on Intel S2600gl.
"Devcon /m:\\srv status pci *" displays 47 device with not installed drivers.
Installer from https://downloadcenter.intel.com/download/20928/Chipset-Driver-for-Windows https://downloadcenter.intel.com/download/20928/Chipset-Driver-for-Windows work out with application error (Intel.Deployment.Branding.CustomAction).
I would be grateful for any help!
Accepted Solutions
What kind of errors do you get?
You might want to try the latest driver version to compare results. https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility- Chipset Driver 10.0.27
Highlighted
David, thank you very much!
In the past, the installation ends with the "unknown" error...
Now the installation is successful
