We have S2600GZ motherboards that are compatible with riser cards F1UL16RISER. We need to buy more of this same riser card, but it is obsolete. We have the next generation card F1UL16RISER2 and it appears to be identical but says it is for R3 slots. Is F1UL16RISER2 the same as F1UL16RISER? Can they be used interchangeably?
Also can F1UL16RISER3 be used instead with the S2600GZ motherboard?
Thanks for your time.
Hello Jds,
The interactive technical support for the Intel® Server Board S2600GZ you have requested has been discontinued. Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help.
You may also find the Discontinued Products website https://www.intel.com/content/www/us/en/support/discontinued-products.html helpful to address your request.
You can additionally check the list of compatible products for the 1U PCIe x16 1-slot Riser Card F1UL16RISER3 here:
Thank you for understanding.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
