Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
4328 Discussions
2 Xeon X5650 with S5520SCR
JBosc4
i build the beklow system, based in S5520SCR:
but ,, when i turn on the computer, chipsets become too hot ant goes very very slowly at point that is about 1hour to install windows
i changed the mother board but happens the same
Intel® Products
Item
Part Number
MM #
Quantity
Description
Intel® Workstation Board S5520SCR
S5520SCR
900963
1
The S5520SCR features Next-Generation Intel® Microarchitecture on a SSI EEB form factor board. Dedicated high speed buses based on Intel® QuickPath Technology
- Two dedicated high speed PCI Express* 2.0 x16 slots
- Scalable memory expansion with 12 DIMMs slots
- IEEE 1394a and 7.1 HD audio support
- Powerful onboard IPMI 2.0 manageability with affordable KVM and remote media redirection upgrade path
Intel® Server Chassis SC5600BASE
SC5600BASENA (with North America power cord) and SC5600BASE
900891 (with power cord) or 900403
1
The Intel® Server Chassis SC5600BASE provides maximum reliability, scalability, and manageability in a highly versatile Intel® pedestal or 5U server chassis
includes:
- One fixed 670W power supply
- Three fixed chassis fans with ducting
- One power supply fan
- Supports up to six tool-free cabled drives, upgradable to six hot-swap drives (SAS or SATA)
Intel® Xeon® Processor X5650 - 2.66GHz (12M Cache, 6.40 GT/s Intel® QPI)
BX80614X5650
907463
2
Requires Heat Sink that supports 95W. Supports DDR3 up to 1333 MHz. Socket compatible with platforms based on the Intel® 5500 series chipsets (LGA1366)
Intel® Thermal Solution STS100C (Combo) Supports processors up to 130W
BXSTS100C
900491
2
Passive/Active Combination Heat Sink with Removable Fan. Supports processors up to 130W.
Installation Instructions:
Step 1: Hold the heatsink with other hand
Step 2: Start first screw with only a couple turns
Step 3: Start second screw (diagonal) with only a couple turns
Step 4: Start third and forth screw with a couple turns.
Step 5: Repeat 2 - 4 until reaching maximum 8 inch pounds of torque.
Note: Do NOT over torque beyond 8 inch pounds
ARIGRACK Pedestal to rack conversion kit
ARIGRACK
908431
1
Kit Includes: hinge cover; rack
handles, intrusion switch jumper, new rail kit
assembly, rack hardware kit, icon label,
installation guide
DSilv11
Valued Contributor III
did you load the FRUSDR code to set the fan control?
Edward_Z_Intel
Community Manager
thanks to everybody i just update the BIOS and works perfectly
regards
josep
