i build the beklow system, based in S5520SCR:
but ,, when i turn on the computer, chipsets become too hot ant goes very very slowly at point that is about 1hour to install windows
i changed the mother board but happens the same
Intel® Products
Item
Part Number
MM #
Quantity
Description
Intel® Workstation Board S5520SCR
S5520SCR
900963
1
The S5520SCR features Next-Generation Intel® Microarchitecture on a SSI EEB form factor board. Dedicated high speed buses based on Intel® QuickPath Technology
- Two dedicated high speed PCI Express* 2.0 x16 slots
- Scalable memory expansion with 12 DIMMs slots
- IEEE 1394a and 7.1 HD audio support
- Powerful onboard IPMI 2.0 manageability with affordable KVM and remote media redirection upgrade path
Intel® Server Chassis SC5600BASE
SC5600BASENA (with North America power cord) and SC5600BASE
900891 (with power cord) or 900403
1
The Intel® Server Chassis SC5600BASE provides maximum reliability, scalability, and manageability in a highly versatile Intel® pedestal or 5U server chassis
includes:
- One fixed 670W power supply
- Three fixed chassis fans with ducting
- One power supply fan
- Supports up to six tool-free cabled drives, upgradable to six hot-swap drives (SAS or SATA)
Intel® Xeon® Processor X5650 - 2.66GHz (12M Cache, 6.40 GT/s Intel® QPI)
BX80614X5650
907463
2
Requires Heat Sink that supports 95W. Supports DDR3 up to 1333 MHz. Socket compatible with platforms based on the Intel® 5500 series chipsets (LGA1366)
Intel® Thermal Solution STS100C (Combo) Supports processors up to 130W
BXSTS100C
900491
2
Passive/Active Combination Heat Sink with Removable Fan. Supports processors up to 130W.
Installation Instructions:
Step 1: Hold the heatsink with other hand
Step 2: Start first screw with only a couple turns
Step 3: Start second screw (diagonal) with only a couple turns
Step 4: Start third and forth screw with a couple turns.
Step 5: Repeat 2 - 4 until reaching maximum 8 inch pounds of torque.
Note: Do NOT over torque beyond 8 inch pounds
ARIGRACK Pedestal to rack conversion kit
ARIGRACK
908431
1
Kit Includes: hinge cover; rack
handles, intrusion switch jumper, new rail kit
assembly, rack hardware kit, icon label,
installation guide
- Tags:
- Intel® Xeon®
did you load the FRUSDR code to set the fan control?
See if this is related to your issue:
http://www.intel.com/support/motherboards/server/sb/CS-031086.htm http://www.intel.com/support/motherboards/server/sb/CS-031086.htm
thanks to everybody i just update the BIOS and works perfectly
regards
josep
