is it possible for a E5-26xx v4 in a 2s board to compete equally against AMD Opteron 6344s in a 4s board?
Checking Specs results (mainly CPU2006), I found several e5-26xx skus that easily double the Opteron 6344 ratings in all aspects, running on all chips, would that be enough to compare the performance of both systems?
Or am I completely misunderstanding Spec results?
Thanks!
Hello martinhain,
You can see the specifications for each E5-26xx here:
http://ark.intel.com/ http://ark.intel.com/
I'm sorry we cannot compare the Intel processors with AMD, if you need to compare these processors you will need to do it through a third party website, perhaps you can try this website:
http://cpuboss.com/compare-cpus http://cpuboss.com/compare-cpus
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
