We are basing an appliance on the intel , which is now 3 seperate components instead of a single sku:R2224GZ4GC, RMS25CB080 & RES2CV360
the bios that ships with the older R2224GZ4GCSAS sku has an incredibly quiet fan speed it defaults to, which is fine, because our appliance will only have low heat hybrid drives, or ssd's.
I have upgraded the bios on one of our test nodes to the latest available for download, which does fix some issues we had with pci bios memory posting errors, however it kicks the fans up to a much louder default speed, and no amount of adjusting settings in the bios is able to fix it.
what can i do to run the new bios, and maintain the fan setting from the shipped bios.
I'm concerned that the bios in the R2224GZ4GC will ship upgraded, and I don't want to have to downgrade.
Try the steps in http://www.intel.com/support/motherboards/server/sb/CS-022809.htm http://www.intel.com/support/motherboards/server/sb/CS-022809.htm. If issue not fixed, check for errors in the SEL.
this did not work, it still idles much faster than the shipped bios in these units. there may be an ever so slight improvement once it actually boots to vmware esxi 5.1, but nowhere near the quiet level that is on the shipped bios.
I just installed these files with startup.nsh
S2600GZ_GL_EFI_BIOS02010002_ME20107231_BMC1195018_FRUSDR111
Our use for this is an appliance, and the quiet was one of the reasons I liked the server. we'll be using laptop hybrids in our config, or ssd's so no need to have the fans spinning fast unless the cpu workload increases.
I downloaded the sel viewer for this system, but have never used it, is this a remote utility, or does it have to run local to the machine?
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21003&keyword=sel&lang=eng SEL Viewer for UEFI/Windows*/Linux* for S1200/S1400/S1600/S2400/S2600/S4600- Mark as New
The SEL Viewer needs to be run locally. But since your system is configured with RMM4, you may also get SEL from RMM4.
Also try to change the BIOS settings below:
Advanced => System Acoustic and Performance Configuration
Choose Altitude for your location. Select "Acoustic" for "Set Fan Profile".
