:-) Hello,
I hope you can help me.
(1st - english isn't my first language, I hope you understand my poor english *embarassed*)
I would like to build a new machine.
2x Xeon E5-2630v2 CPUs with a Mobo with 4x PCIe x16 slots for 2 slot wide graphic cards.
As far as I know, Intel have at least two Mobos with this specs?
Intel Workstation Board W2600CR2: http://ark.intel.com/products/56338 http://ark.intel.com/products/56338
Intel Server Board S2600IP4: http://ark.intel.com/products/56337 http://ark.intel.com/products/56337
Just this two Mobos?
If I buy today one of this both Mobos (I live in Germany), their BIOS support the new E5-2630v2 CPUs?
In the specs, supported RAM:
DDR3 ECC UDIMM 1600, RDIMM 1600, LRDIMM 1333
DDR3 ECC UDIMM/LV RDIMM/LV 1066 1333 1600, Load Reduced 1333 1333LV
Does this mean I could use regular (non ECC) unbuffered system RAM also?
I mean for example (4x 4GB, for each CPU):
16GB G.Skill RipJawsZ DDR3-1600 DIMM CL7 Quad Kit
16GB Corsair XMS3 Dominator DDR3-1600 DIMM CL7 Quad Kit
Where I could find infos about which system RAM would be recommended for the above mentioned Mobos (or the other Mobos which you know with the above mentioned specs)?
:-) Thank you a lot.
Both boards should support Xeon E5-2600 v2 series CPUs if BIOS 1.08 or later is installed. For more technical specs of the boards see http://www.intel.com/support/motherboards/server/sb/CS-033140.htm Technical Product Specification.
For tested memory list, visit http://serverconfigurator.intel.com/ http://serverconfigurator.intel.com/ and click "THOL Builder".
