Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
5520SC Network Driver Device ID 10AA
AAndr33
Hi!
I bought an used Intel 5520SC and it looks like the network eeprom is corrupt because it shows 10AA as Device ID and no driver is working. Is there any chance to correct this? There is of course no warranty left.
Kind regards, Andreas
01:00.1 Ethernet controller: Intel Corporation Device 10aa (rev 02)
Subsystem: Intel Corporation Device 0000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin B routed to IRQ 10
Region 0: Memory at c3200000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at 3000 [size=32]
Region 3: Memory at c3240000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
The board you are looking support is end of interactive support (EOIS). As a general recommendation make sure you have the latest firmware and latest network drivers:
https://www-ssl.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005518.html?wapkw=006120 Intel® PRO/100 Adapter Software and Drivers
Intel® Server Board S5520HC S5500HCV S5520HCT S5520SC Firmware Update Package for EFI
