Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4953 Discussions
AC coupling cap location PCIe
D-1718T
Section 6.11.1 Idaville LCC PDG
"The AC coupling capacitors should be placed reasonably close
to the transmitter for the PCIe interface for test purposes. This rule is based on the
PCIe specification, but it typically does not matter where the capacitors are placed.
Placing them near the transmitter gives a convenient point to measure the transmitter
output."
We have a design constraint that makes it more desirable for the AC caps to be closer to the receive end of the transmission line than the transmit driver.  Placement was at the receive end of the PCIe pair in our previous generation board as well and we did not have an SI problem.
The text in the PDG states, "typically does not matter where capacitors are placed".  Should we be concerned if the caps are closer to the receive end than the transmit end?
RamyerM_Intel
Hello D-1718T,
I have sent you a private message to make sure that we would be able to converse with privacy and security. Kindly please check your inbox for messages as this inquiry might contain some sensitive information. Please check your inbox for messages.
Ramyer M.
RamyerM_Intel
Hi D-1718T,
As promised, I will be moving this post to our server forum for faster answers. Thank you for your patience and cooperation.
Ramyer M.
Azeem_Intel
Hi D-1718T,
Greetings for the Day!
Hope you are doing well. Since we're from the technical team, we don't have the information you've requested, Please contact the RDC team using the link provided below for assistance.
Resource & Documentation Center (intel.com)
Azeem.
Azeem_Intel
Hi D-1718T,
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Azeem.
Azeem_Intel
Hi D-1718T,
Azeem_Intel.
Azeem_Intel
Hi D-1718T,
Azeem_Intel
