Server Products
4778 Discussions
ASR26XXFH3XR - 3 PCI-X Full size ?
I know that is possible install on SR2600URLX a 3 x full-height PCI-X 133 MHz riser card.
I don't find any specification about this riser card and I need to be sure that on this server with this riser card is possible installing number 3 card PCI-X FULL SIZE.
Is it possible?
Where I can find more details about this riser card on web site? It seems impossible.
Thank you very much!
bye
Edward_Z_Intel
Hi Edward,
thank you for your answer but I have already red the document and it wasn't very useful:
On section 9 page 78, I could read (Table 58. Riser Card Options):
2U PCI-X Active Riser
(Product Order Code – ASR26XX____)
One Full Height PCI-X 133Mhz connector
Two Full Height PCI-X 100Mhz connectors
The "Full Height" definition means that we could put a board that isn't Low profile but doesn't give me any information about the length size (if half/mid length or full length that is a full size board). Moreover on the chapter 9.2: "PCI Riser Card Mechanical Drawings" the 2U PCI-X Active Riser isn't reported..
What I'm expecting is a definition like this:
full-height, mid-length PCI-X 133 MHz
or
full-height, full-length PCI-X 133 MHz
That were definitions of PCI slot of the old server series (i.e. SR2500 / SR1530)
I hope that now is more clear what I need...
Thank you
Daisy
Daniel_O_Intel
How long is the riser card you plan to install?
Hi Dan,
the board is a Dialogic Diva PRI E1-30 PCI with these dimensions:
— V-, UM-, PRI/E1-30 / T1-24 PCI/PCIe: 312.00 mm x 111.15 mm (PCB)
— V-, UM-, PRI/E1-30 / T1-24 PCI/PCIe: 325.31 mm x 126.31 mm (with bracket)
— V-, UM-, PRI/E1-30 / T1-24 PCI/PCIe: 352.17 mm x 126.31 mm (with bracket and retainer)
http://www.dialogic.com/products/tdm_boards/media_processing/docs/11233-diva-pri-ds.pdf http://www.dialogic.com/products/tdm_boards/media_processing/docs/11233-diva-pri-ds.pdf
Of course we could remove the retainer.
Thank you
Daniel_O_Intel
That's going to be a tight fit. It's 31cm from the front to the back of the riser card insert, by my unofficial lab measurement. Also, any portrusions on the card might hit the chipset heatsink, if the card is put on the bottom-most slot.
