We are system builders from Santiago Chile, Intel channel member Business ID:# 10461610 and recently some clients are asking us about workstations. We`re buying two XEON 5506 along with the board Asus Z8NA-D6C and PNY NVIDIA QUADRO FX 4800
The purpose of this workstation is for rendering and modelling with MAYA and 3DMAX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117186 http://www.newegg.com/Product/Product.aspx?Item=N82E16819117186
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131378 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131378
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133252 http://www.newegg.com/Product/Product.aspx?Item=N82E16814133252
My question is about memory configuration, Its true this processors works with DDR3 800mhz memory modules, but we can not find those frequecies here in the market, only DDR3 1066 and 1333
Can we use this memory pack with the above configuration?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820609459 http://www.newegg.com/Product/Product.aspx?Item=N82E16820609459
and set the frequency to 800mhz?
What is the best configuration?
Would you be so kind and help me a bit with this dilema?
I would be much appreciated
Thank you
Rodrigo Bayer Bachler
Director
mybox.cl
+569 90430230
mailto:ventas@mybox.cl ventas@mybox.cl
- Tags:
- Intel® Xeon®
On the processor side yes E5506 will slow down 1066 or 1333 MHz DIMM to 800 MHz. However you may want to check with board vendor whether this DIMM model has been validated or not.
