Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Adaptec 6405 and Intel Board DBS1200V3RPS
SKorn1
I have an Adaptec 6405 controller which I want to use with Intel Board DBS1200V3RPS. But the controller gets not detected by the board, it just does not appear while starting the system. I am using latest BIOS (BIOS02020005) for the Board. I am using Slot 5 (PCIe x8). Is there anything I can do on this?
David_A_Intel
I was checking the validation list for this board and I could not find this model listed. Intel always recommends using validated components to avoid unforeseen issues.
You may use our https://serverconfigurator.intel.com/exalt/MyPartsServlet?iMethodID=4&dataset=IntelTHOL&basefilters=column1_IN_S1200V3RPL_AND_column3_IN_P4308RPLSHDR&title=Options%20Page&hidedisabled=y&bypass=y Tested Hardware and Operating System List document as a reference.
You may also want to disable the Quiet Boot option in the BIOS to see if the RAID controller is starting up while we are getting the splash screen.
http://www.intel.com/support/motherboards/server/sb/CS-034669.htm Unable to Enter BIOS Setup or Intel® RAID BIOS Console During Boot.
David_A_Intel
SKorn1
Thank you, disabling Quiet Boot Option did the trick, Controller BIOS does now appear. I tried to remove the Intel boot screen by pressing ESC previously but this did not work.
Also very nice tool at https://serverconfigurator.intel.com/ https://serverconfigurator.intel.com/ - I will definitely bookmark this one
