Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4502 Discussions
Adding SAS drives to SR1625URR / S5525URR server
The SR1625URR basic configuration with passive midplane allows SATA disks to be connected, the SATA drives can run with on-board limited raid.
I was checking possibility to add SAS drives instead, from what I have found, this server has alternative called SR1625URRSAS, the URR version has passive midplane, the URSAS has active midplane, allowing SAS drives.
If i understand the docs right, its not possible use SAS drives with passive midplane? or there is some option, or they can run without raid in this config?
If i buy the active midplane called FALSASMP2, this makes the system upgraded to SR1625URRSAS or something else is missing? Can I use SAS drives in raid with the active midplane without DIMM RAM/key? or I need full h-w raid support to use raid with this card? (I assume the basic SR1625URRSAS package comes without the dimm/key on the midplane, I'm not sure if it is raid ready with this setup)
if its possible to use active midplane for sas in raid without the activation key, is it seriously limited in regular performance? or the h-w key/memory just allows additional perfomance and drop backup?
the goal is to have raid10 array, preferably with SAS as the 2.5" SATA with good performance are not much available or come with similar price with worse performance, or anybody has good setup/experience using them for raid10?
Kimic
Edward_Z_Intel
If you already have a SR1625UR system, you can add a SAS RAID controller to use SAS drives. Below you can find supported RAID controllers:
http://serverconfigurator.intel.com/sctthol.aspx?search=Server+System+SR1625URR http://serverconfigurator.intel.com/sctthol.aspx?search=Server+System+SR1625URR
If you want to go with SR1625URSAS, yes it comes with SAS support. This little tool can help you to choose the correct RAID configuration:
http://www.intel.com/support/motherboards/server/sb/CS-030410.htm http://www.intel.com/support/motherboards/server/sb/CS-030410.htm
Edward_Z_Intel
So having the URR version, starter solution would be going for FALSASMP2 to enable 3G SAS RAID, and add key/memory later for higher reliability, but lacking the 6G support
or to get 6G SAS support out of the box with passive mid and AXXRMS2MH080 RAID controller
