Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Amber led at the rear view of the S2600GZ box..looks like on the mother board
Kt7
I have a amber light at the rear view of the S2600GZ box.
The light is inside the chassis near to MGMT port and I can't find any material showing what the led means. No issue with the server overall. Check Attachment
Any help would be appreciated
Hello Kamlesh,
With the amber light on the back of the system near the MGMT port. Is part of the serious of LED status. This information can be found at the http://download.intel.com/support/motherboards/server/sb/s2600gzgl_tps_r2_4.pdf Technical Product Specs, page 95 (10. Light Guided Diagnostics). First I will recommend to plan some down time, this will help you to open the server and verify the exact light that is Amber, but also can double check:
  • If there is no other amber lights on the system board.
  • If the system is only running one memory stick.
  • If all FANs are running.
  • And if you are able to boot to the OS
If there is anything else we can help please feel free to ask.
Henry A.
Kt7
The server is up and running with no issue at all. All fans are populated and
Power Management: Ok
Power Supplies: Ok
Processors: Ok
Intrusion: Ok
Voltages: Ok
Hardware Log: Ok
Fans: Ok
Temperatures: Ok
Memory: Ok
Battery: Ok
Raid: Ok
Storage: Ok
Physical Disk:
Slot 0: Online, Active
Slot 1: Online, Active
Slot 2: Online, Active
Slot 3: Global HotSpare, Active
Cannot get device settings: No such device
Cannot get wake-on-lan settings: No such device
Cannot get message level: No such device
Cannot get link status: No such device
Network Conn:
bond1 -- link ok, Speed: , Duplex: , Auto-negotiation:
bond2 -- no link
bonding_masters -- no link
eth0 -- link ok, Speed: 1000Mb/s, Duplex: Full, Auto-negotiation: on
eth1 -- link ok, Speed: 1000Mb/s, Duplex: Full, Auto-negotiation: on
eth2 -- no link
eth3 -- no link
eth4 -- no link
eth5 -- no link
The server has been replaced twice but the issue happened repeatedly.
In the /var/messages log i do see these error
Feb 24 16:11:50 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Supply 2 ok
Line 88305: Feb 24 16:11:50 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Fully Redundant
Line 91494: Mar 2 23:04:22 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Redundancy Lost
Line 91495: Mar 2 23:04:25 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Fully Redundant
Line 94059: Mar 7 19:26:43 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Supply 2 failing
Line 94060: Mar 7 19:26:43 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Redundancy Lost
Line 94061: Mar 7 19:26:46 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Supply 2 ok
Line 94062: Mar 7 19:26:46 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Fully Redundant
Line 95242: Mar 10 02:50:14 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Redundancy Lost
Line 95243: Mar 10 02:50:16 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Fully Redundant
Line 95644: Mar 10 19:23:21 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Redundancy Lost
Line 95645: Mar 10 19:23:24 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Fully Redundant
Line 102750: Mar 24 05:00:32 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Supply 2 failing
Line 102751: Mar 24 05:00:35 SMOLISPDSFMA1 hwmon: Power Supply Alert: Power Supply 2 ok
Line 120556: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 1A Failed
Line 120557: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 1B Failed
Line 120558: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 2A Failed
Line 120559: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 2B Failed
Line 120560: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 3A Failed
Line 120561: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 3B Failed
Line 120562: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 4A Failed
Line 120563: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 4B Failed
Line 120564: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 5A Failed
Line 120565: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 5B Failed
Line 120566: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 6A Failed
Line 120567: Apr 28 07:16:36 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 6B Failed
Line 120568: Apr 28 07:16:48 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 1A Ok
Line 120569: Apr 28 07:16:48 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 1B Ok
Line 120570: Apr 28 07:16:48 SMOLISPDSFMA1 hwmon: Fan Alert: Fan 2A Ok
Line 120571: Apr 28 ...
Hello Kamlesh,
Thank you for the information provided. The system is reporting several problems with Power Supply and fans going off-line and then back on-line.
Are you using an Intel Chassis?
Please ensure that the power supply is connected to a proper UPS or if possible to connect it to a different outlet.
Also, I will recommend to flash BIOS to latest version, or re-flash BIOS to ensure the BMC detects all FANs and Power Supply configuration. The latest https://downloadcenter.intel.com/download/26618/Intel-Server-Board-S2600GZ-GL-Firmware-Update-for-Intel-OFU-and-WinPE-?product=77886 BIOS can be download from our web site. Extract the information and please follow the information on the S2600GZ_GL_Update_Instructions.txt file.
Henry A.
Hello Kamlesh,
Henry A.
Hello Kamlesh,
This is a follow up on your questions related to S2600GZ box with some amber lights on the motherboard. If the information provided helped or if there is something else I can help. Or if it is OK to close the interaction.
Henry A.
Hello Kamlesh,
Henry A.
Hello Kamlesh,
Henry A.
zmrad
Dear my friend
I Try everything and still the fans noisy ,anyhelp
thank you
zmrad
Hello
I want ask you about server chassis if i dont put the screw this may coz this problem and can you give me an image how to close the chassis correctly.
Thank you
Regards​
