Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4482 Discussions
Ayuda se me quemo la fuente de un Intel SR1560SF con el numero de parte D94853-003 y consigo D94853-005 como recambio lo que quiero saber es si son compatibles ya que las especificaciones son iguales muchas gracias
OAlva
Hola ayuda !!!
OAlva
HELP No se de donde puedo sacar esas comparaciones
Hello Omar-patecc,
After checking both part numbers for the power supply they are exactly the same, the only main difference it is that part number D94853-005 comes with a higher revision.
If you need further assistance replacing the power supply for your Intel SR1560SF server please check the following URL http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5400sf/sb/sr1560sf_ser... http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5400sf/sb/sr1560sf_ser...
page 51 Replacing the Power Supply
If you need further assistance please contact us back.
Hello Omar-patecc,
This is a follow up message just to check if there are any questions related to this same issue. Otherwise if you consider this issue as resolved we can proceed to mark this thread as closed.
Best Regards.
