Does anyone have bios dump ".bin" file for S2600CW2R?
I have tried everything
- change RAM
- change CPU
- turn off everything besides CPU and RAM
- change PSU
- tried to update BIOS
but 4F error persist.
I can not update BIOS because no USB is working, so I can not put USB stick and run update procedure. PCI-e to USB also not working. System is not booting, can not get into BIOS at all, hanging on 4F error all the time. There are no errors of RAM or CPU. After checking those two components (and other I think) board hungs up.
0x4F | DEX IPL Started |
Intel does not provide .bin files.
Hello zerbatin,
In order to help you can you please provide the following:
- Are you using an Intel chassis or a third-party chassis? Can you please provide the exact model?
- Have you tried to clear the CMOS or complete a BIOS recovery?
- Are you using one or two processors? Can you please provide the exact model?
- Have you tried the system with minimal configuration (1 stick of RAM, 1 CPU, and 1 PSU)?
- Please provide the exact model of memory that you have installed, the amount of DIMMs being used, and the DIMM population you currently have.
- Was the system working properly before? If yes, were there any hardware or software changes that might have caused this problem?
- Was the baseboard management controller (BMC) configured? If yes, do you have access to it? If yes, please provide the SEL logs. These logs can be extracted by going to BMC Console > Server Health > Event Log > Save Event Log.
Victor G.
Intel Technical Support Technician
Hi Victor,
Thank you for reply. My answers are:
1. I am using 3rd party chassis - Corsair Obsidian 850D, but board was also in CoolerMaster ST01C and outside any chassis.
2. Yes, I have tried both solutions.
3. I am using 2 processors, but also tried running with one. I have two Xeon 2650v3 (not EE, ES), and I am using them all the time (with other board). I've also tried using Xeon 2667v4 (not EE, ES).
4. Yes, I have tried all solutions that you mentioned.
5. a) with xeon 2667v4 I have tried one stick 32GB 2Rx4 PC4-2400T-RB1-10 HMA84GR7MFR4N-UH TD AB 1551
b) with two xeons 2650v3 I have tried
- two sticks 8GB 2Rx8 PC4-2133T-RA0-10 HMA42GR7MFR4N-TF TD AA 1519
- two sticks 16GB 2Rx4 PC4-2133P-RBB-10 MTA36ASF2G72PZ-2G1B1II 1613
c) with one xeon 2650v3 I have used
- two sticks as well as one stick 8GB 2Rx8 PC4-2133T-RA0-10 HMA42GR7MFR4N-TF TD AA 1519
- two sticks as well as one stick 16GB 2Rx4 PC4-2133P-RBB-10 MTA36ASF2G72PZ-2G1B1II 1613
- one stick 16GB 2Rx4 PC4-2133P-RA0-10 HMA42GR7MFR4N-TF TD AA 1519
6. No, it is new board (I bought it as new, but can not return).
7. I can not get into BMC, If I could I would have managed.
Jakub L.
Hello zerbatin,
After checking the components you are using, the RAM and processors show up as compatible under the
https://servertools.intel.com/sct/compatibility-tool/S2600CW
About the 3rd party chassis, you want to confirm the compatibility directly with the chassis OEM
You stated no USB ports are working, so there might be some actual hardware failure on this board. Probably you want to check its current warranty status on this Intel URL: https://supporttickets.intel.com/warrantyinfo?lang=en-US
If the board is still under warranty, Intel should be able to get it replaced
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Hello zerbatin,
Please let me know if you still need further assistance.
Victor G.
Yhank you for reply. As I wrote in my first post I need a dump of BIOS from another motherboard (made with ch341a and clip or any other chip programmer, in "*.bin file 16MB) BIOS is corrupted and that is why my motherboard will not boot properly.
The chassis is not the problem, as well as other components, just corrupted BIOS.
It is not udnder warranty because someone pealed off the stickers.
And, using a bin file for your board steals the idenity of another board. It is wrong to do this.
Hello zerbatin,
Thank you for your response.
In this case, from our end, there is no more assistance that can be provided based on your situation. We wish you the best of luck with your system. Please bear in mind that this thread will no longer be monitored. In case you need anything else from our end in the future don’t hesitate to create a new thread.
Victor G.
