Server Products
Bifurcation
JamesT65
Hi Support,
We are testing a Mobo M50CYP2SB2U. (Board Chipset Intel® C621A Chipset) with 2 x  Network Adapter E810-CQDA2
We have set the CPU 0 and CPU 1 to allocate x8x8 in the bios to the two E810 boards and it has no effect on the throughput, we are testing 100Gbps per port and we can only get 100Gbps max at any one time, can someone confirm if this Mobo can support Bifurcation or do we need the UR board or a specific riser card?
Victor_G_Intel
Hello JamesT65,
To continue with your request would you mind providing the following information:
1-Is this server board part of an Intel® Data Center Blocks (Intel® DCB)?
2-Can you please share with us the steps that you followed in order for you guys to partially set up the bifurcation by allocating the two x8 PCIe lanes with both CPU 0 and CPU 1? A picture of the specific section or sections used will be very much appreciated as well.
3-Please confirm the specific model of motherboard that you have from the link below:
https://ark.intel.com/content/www/us/en/ark/products/series/201606/intel-server-board-m50cyp-family.html
Note: The M50CYP2SB2U doesn’t show in our records.
4-Do you have the board’s BMC (Baseboard management controller) configured?
Note: If you have the BMC configured please provide the following logs if possible:
Debug log
Instructions:
https://www.intel.com/content/www/us/en/support/articles/000027943/server-products.html?erpm_id=9125055_ts1628805647778
SEL log
Instructions:
To Generate the SEL log from within the Server please use the following path directly in your baseboard manager controller: BMC Health->Event Log->Save Event Log section.
5-A Sys info log will also be helpful if possible:
Sys info log
System Information Retrieval Utility (SysInfo) Download link*
https://www.intel.com/content/www/us/en/download/17949/system-information-retrieval-utility-sysinfo.html
Instruction’s guide:
https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html
Video instructions
https://www.intel.com/content/www/us/en/support/articles/000032842/server-products.html
I look forward to hearing from you.
Victor G.
JamesT65
Hi Viktor,
thanks for the info, we will collect it and come back to you.  Our board is as stated it is a pre-release board that we are testing.
Victor_G_Intel
Hello JamesT65,
Thank you so much for your response.
We will be waiting for the information.
Victor G.
Victor_G_Intel
Hello JamesT65,
I have sent you a private email in regards to the current threads open under your name, please read it carefully and reply to it privately.
Victor G.
Victor_G_Intel
Hello James T65
As per our previous conversation via private email, please continue with the assistance by using either one of the support channels found in the link down below:
Intel® Software Development Platform (Intel® SDP)
https://www.intel.com/content/www/us/en/secure/design/ipla/software-development-platforms/support.html
Victor G.
