Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
Bios
Hi
I have instal on my machine 2 processors E5410, my board is a s5000xvn, but when the machine starts apears a fatal error 19A.
Processor voltage mismatch detected.
The error code value identifies the error
Fatal sevrity requires user intervention and prohibits system boot.
Wha can i do for solve this problem?
thk
Edward_Z_Intel
Boot with one CPU and update BIOS/firmware. What's the sSpec# of your CPUs? sSpec# is a 5-letter string on the CPU starts with "SL"
DSilv11
Valued Contributor III
Is you board a S5000XVN or S5000XVNR? You will likly need to check the mother board part number to tell. It should be displied under system management - system Information in BIOS set-up
E11034-xxx or E11030-xxx should work with the E541=0
The original S5000XVN only supports 50xx, 51xx & 53xx processors,
The refresh version added a circuit to swith the core voltage to support 52xx,& 54xx,
If you install a E5410 on an pre-refresh S5000XVN you will get a "Processor voltage mismatch detected." error.
http://www.intel.com/support/motherboards/server/sb/CS-028540.htm http://www.intel.com/support/motherboards/server/sb/CS-028540.htm
