Server Products
4784 Discussions
Brackets for RS3DC040
RKraw
Do you provide full profile PCIe brackets for Intel RS3DC040 RAID controller ? The product form factor is low profile, yet no information is given if both full profile and low profile brackets are provided.
Best Regards
Hello 135,
The RS3DC040 RAID controller comes with both brackets, full height and low height profile. Please refer to http://ark.intel.com/products/77347/Intel-RAID-Controller-RS3DC040 Intel-Raid-Controller-RS3DC040 to find more about the items that are included.
Franklin S.
Hello 135,
In order to provide you the correct info let me ask you the following:
Is your server a pedestal or rack mounted chassis server?
When you say full and low profile do you mean 1U, 2U form factors?
Could you please provide the server model number?
What happens is that usually the PCI risers, brackets and other accessories are listed under the server model configuration guide for the chassis
In the following URL you could look for information related.
https://www.intelserveredge.com/products-services/chassis/ https://www.intelserveredge.com/products-services/chassis/
Hope this helps.
Jose H.
Hello 135,
Franklin S.
RKraw
Thank you,
This is exactly wjat I wanded to know. Does This also concern the entry series RAID as below ?
RS3WC080
Best Regards
