Server Products
4784 Discussions
Bricked S2600G(L/Z)?
stemp2
Hi Guys,
So i was trying to upgrade firmware on my server.
I ran flashupdt -u \flashupdt.cfg and went away when it was "Upgrading HBSP and PSU firmware..."
After i came back the server was running - fans were spinning but no signal on the screen. I left it running for couple of minutes but there was no change so i rebooted the server - it didn't come back.
System Status LED is solid Amber and 2nd,3rd green POST LED is on which means: 06h Early CPU initialisation during Sec Phase. and it stays like that forever.
I tried to swap CPUs, run with only one CPU (both CPUs tested) and the error is always the same.
Then i tried to flash using BIOS Recovery Procedure and i'm getting 1st,4th green LED on and 1st,2nd,3rd,4th Amber LED ON with 2 Beeps and 4 Beeps in the background.
I also tried different CPU configuration and nothing helps.
The only difference i see (i think so) is when i have USB drive inserted and not inserted.
When there's no USB Mass Storage beeps happens so quickly as described in the manual but when i insert the USB there's 1 second break between each set of beeps. Maybe i'm doing something wrong?
Does it means i bricked motherboard?
stemp2
Attaching Event Log from flashing process:
stemp2
Looks like it didn't flash the bios cause RMM reports old version:
stemp2
Another update
After 2 beeps the lights go "ON" on the USB Stick so it means it's trying to read something but it can't?
Hello Sayetan,
In regards to your issue, you can try to move the BIOS recovery jumper block from its default pin position, the system will boot into a BIOS Recovery mode. This procedure It is used when the system BIOS has become corrupted and non- functional, such as your case, requiring a new BIOS image to be loaded. Please the check the technical product specification https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/s2600gzgl_tps_r2_4.pdf here for more detailed information, page 92.
Please do not hesitate to contact us again if you need further assistance.
Sergio S.
stemp2
Hi Sergio,
Thanks for your answer but as already stated in the second part of my opening post i have already done that.after two beeps it tries to read pendrive cause lighta on it are blinking but suddenly i get another foir beeps which meana it cant read RML.ROM from it. The recovery procedure is pretty simple, pit files on the root of usb drive, change the jumper and power on the server. Is there any special requirements?
Hello Sayetan,
As an additional troubleshooting step shut down the server and disconnect the AC power cord from the main socket, remove the CMOS battery for 5 minutes and hold down the power button in order to completely drain the power of your system.
Then, place the battery again and try to turn you system again.
Sergio S.
stemp2
This didn't help - same issue again...
Can you please have a look on the video and the logs because from what i can see it's:
- 00:31 it starts the recovery F2h - Recovery PEIM (Recovery Started)
- 00:32 F3h - Recovery PEIM (Capsule found)
- 00:33 It fails. 4 beeps means BIOS Recovery Failed but what LEDs indicate, i couldn't find that code in the manual.
video: https://www.youtube.com/watch?v=e2Ltm0DrSAo&feature=youtu.be Intel BIOS Recovery Fails - YouTube
debug logs attached to a ticket
When i run in normal mode with both CPUs i get Status ID SOLID AMBER and error code: 06h - Early CPU initialization during Sec Phase
When i run in normal mode with one CPU i get Status ID SOLID AMBER and error code: 09h - End of Sec Phase
System Event Log from normal boot attached
IMPORTANT: can you confirm it's a motherboard and not something else that failed? I want to be sure before i spend money on new motherboard?
EDIT: I was going through the logs from flashing process. CATERR are realted to CPU/Memory, would they be triggered in failed BIOS flash?
EventID:1163 Time Stamp:06/25/2017 11:04:01 SensorName:FW Update Status Sensor Type:Version Change Description:Update started for BMC instance 0. Version 1.17. Build ID 4151. -Asserted
EventID:1164 Time Stamp:06/25/2017 11:05:57 SensorName:FW Update Status Sensor Type:Version Change Description:Update completed successfully for BMC instance 0. Version 1.27. Build ID 9958. -Asserted
EventID:1165 Time Stamp:06/25/2017 11:07:08 SensorName:PS2 Status Sensor Type:Power Supply Description:reports the power supply's presence has been detected -Deasserted
EventID:1166 Time Stamp:06/25/2017 11:07:12 SensorName:SAS Mod Presence Sensor Type:Module / Board Description:reports the device has been inserted or is present -Asserted
EventID:1167 Time Stamp:06/25/2017 11:07:54 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports full redundancy has been regained -Deasserted
EventID:1168 Time Stamp:06/25/2017 11:07:54 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports redundancy has been lost -Asserted
EventID:1169 Time Stamp:06/25/2017 11:07:54 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports redundancy has been lost, but the unit is still functioning with the minimum amount of resources needed for normal operation -Asserted
EventID:1170 Time Stamp:06/25/2017 11:11:51 SensorName:HDD 0 Status Sensor Type:Drive Slot (Bay) Description:Drive Presence -Asserted
EventID:1171 Time Stamp:06/25/2017 11:11:51 SensorName:HDD 1 Status Sensor Type:Drive Slot (Bay) Description:Drive Presence -Asserted
EventID:1172 Time Stamp:06/25/2017 11:11:51 SensorName:HDD 2 Status Sensor Type:Drive Slot (Bay) Description:Drive Presence -Asserted
EventID:1173 Time Stamp:06/25/2017 11:11:51 SensorName:HDD 3 Status Sensor Type:Drive Slot (Bay) Description:Drive Presence -Asserted
EventID:1174 Time Stamp:06/25/2017 11:11:52 SensorName:FW Update Status Sensor Type:Version Change Description:Update started for BIOS instance 0. Version 1.6.0002. -Asserted
EventID:1175 Time Stamp:06/25/2017 11:13:24 SensorName:SMI Timeout Sensor Type:OEM Reserved Description:reports it has been asserted -Asserted
EventID:1176 Time Stamp:06/25/2017 11:13:49 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports redundancy has been lost -Deasserted
EventID:1177 Time Stamp:06/25/2017 11:13:49 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports redundancy has been lost, but the unit is still functioning with the minimum amount of resources needed for normal operation -Deasserted
EventID:1178 Time Stamp:06/25/2017 11:13:49 SensorName:SMI Timeout Sensor Type:OEM Reserved Description:reports it has been asserted -Deasserted
EventID:1179 Time Stamp:06/25/2017 11:13:51 SensorName:Pwr Unit Redund Sensor Type:Power Unit Description:reports redundancy has been lost -Asserted
EventID:1180 <span c...
Hello Sayetan,
With all this information, it looks like the problem is the motherboard. But on the beginning of the conversation, you stated testing different CPU configuration. Does the system has more than one CPU and how many memory sticks. If more than one on either CPU or Memory, I will recommend to test one CPU and one memory stick at a time.
If there is anything else we can help please feel free to ask.
Henry A.
stemp2
Hi Henry,
Thank you for looking at this. So you recon it's not broken due to flash failure?
Server has 2 cpus and 12x 8GB memory sticks
Please see my last post i pasted error codes i was getting with one cpu A1B1 occupied and 2xcpu A1B1 E1D1 occupied
From the top of my head i can't tell you all different configurations i tried so far. I'm away till saturday but when i'm back i will test as many different configurations as possible
Andrzej
Hello Sayetan,
Thank you for the update. Then at this moment it sounds like the system board needs replacement. Best option will be to contact your local Intel Authorized Reseller or place of purchase to other a replacement.
If for any reason they are not able to help you, please provide us with:
  • System board PBA number.
  • System board Serial number.
  • Company name and ID number for Intel.
  • Contact name and address for the replacement.
Henry A.
stemp2
Hi Henry,
So i tried to contact the company i bought the server from but no reply - they already know i was trying to flash bios and they said they are not taking responsibility . It was a surplus and i bought it on ebay.
I'm not able to provide company name and ID because i bought that server for myself for my homelab to learn IT.
Can you please let me know if i'm eligible for the replacement cause if not i will start looking for a spare one on ebay.
Andrzej
Hello Sayetan,
  • Copy of the proof of purchase and where it was bought from.
Henry A.
Hello Sayetan,
  • Copy of the proof of purchase and where it was bought from.This will help me verify warranty.
Henry A.
We just sent you a private message requesting some additional information.
Regards.
stemp2
Sent you additional information
Hello Sayetan,
I am sorry about the dealy. We are still verifying the information you provided us. This because normally items purchased in eBay does not have warranty with Intel. But I am still checking on this. I will get back with you as soon as possible.
Henry A.
CEvan3
Thank you for your support. It does help me a lot!
https://spanishto-english.com/ spanish to english
stemp2
Hello Sayetan,
I am sorry about the delay. At this moment the best option will be to contact your region support tea. Please check on the following web site for the https://www.intel.pl/content/www/pl/pl/support/contact-support/emea-contact.html Contact Center.
Henry A.
stemp2
Hi Henry,
Could you please be more specific and explain to me why would i need to contact my region support team? Forgive me but for me you sound more like a bot than a human. Your answers are rather general than specific.
This is going for more than a week and the only thing i know is my "motherboard needs to be replaced". No information what failed, no information why it failed.
Please sound more like a human.
