Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4778 Discussions
Bricked S2600G(L/Z)?
stemp2
Hi Guys,
So i was trying to upgrade firmware on my server.
I ran flashupdt -u \flashupdt.cfg and went away when it was "Upgrading HBSP and PSU firmware..."
After i came back the server was running - fans were spinning but no signal on the screen. I left it running for couple of minutes but there was no change so i rebooted the server - it didn't come back.
System Status LED is solid Amber and 2nd,3rd green POST LED is on which means: 06h Early CPU initialisation during Sec Phase. and it stays like that forever.
I tried to swap CPUs, run with only one CPU (both CPUs tested) and the error is always the same.
Then i tried to flash using BIOS Recovery Procedure and i'm getting 1st,4th green LED on and 1st,2nd,3rd,4th Amber LED ON with 2 Beeps and 4 Beeps in the background.
I also tried different CPU configuration and nothing helps.
The only difference i see (i think so) is when i have USB drive inserted and not inserted.
When there's no USB Mass Storage beeps happens so quickly as described in the manual but when i insert the USB there's 1 second break between each set of beeps. Maybe i'm doing something wrong?
Does it means i bricked motherboard?
PElde
Question: How is the flash drive formatted that is being used to run the BIOS recovery step?
We keep a couple 512MB (yes, MB! ) and 1GB sticks formatted FAT32 just for this purpose.
stemp2
Hi Philip,
I thought this could be the issue but i wasn't able to find any useful information about the recovery drive.
the smalles capacity i have is Kingston DataTraveler:
DISKPART> detail disk
Kingston DataTraveler 2.0 USB Device
Disk ID: {E3EFC71A-2412-463B-A8B8-7A21FCDCC4F1}
Type : USB
Status : Online
Path : 0
Target : 0
LUN ID : 0
Location Path : UNAVAILABLE
Current Read-only State : No
Read-only : No
Boot Disk : No
Pagefile Disk : No
Hibernation File Disk : No
Crashdump Disk : No
Clustered Disk : No
Volume # Ltr Label Fs Type Size Status Info
DISKPART> list partition
Partition # Type Size Offset
Partition 1 System 7654 MB 1024 KB
stemp2
You are the man Philip!!!
I used 2GB usb stick and it recovered the BIOS!!! Thank you very much for your answer i really appreciate it!
USE =<2GB USB STICK TO RECOVER YOUR BIOS</strong>
Hello Sayetan,
I am sorry about the delay. At this moment the best option will be to contact your region support tea. Please check on the following web site for the https://www.intel.pl/content/www/pl/pl/support/contact-support/emea-contact.html Contact Center.
If there is anything else we can help please feel free to ask.
Henry A.
Hello Sayetan,
I am sorry if I sounded like a bot, I am human. And I am sorry I did added the information why you need to contact your region https://www.intel.pl/content/www/pl/pl/support/contact-support/emea-contact.html Contact Center. The reason is because they will be able to provide you with the best options for warranty. And the reason for a possible failure, I am afraid there is not one. When you flash firmware's anything can go wrong.
Henry A.
stemp2
Apologise, i just got mad when i saw you replying the same formula to a bot as if it was me.
Hello Sayetan,
We are following up your case and we would like to know if your need further assistance.
Sergio S.
stemp2
Hi Sergio,
I was pretty busy recently and i didn't have time to ring/e-mail support in UK. I will try to do that ASAP and come back to you.
No problem , please keep us posted.
stemp2
So everything is back as it was when i bought the server
one issue i had during the firmware update process:
1. I recovered to the same BIOS version as i had before
2. Upgraded to version 01.08.0003. During SDR/FRU update it detected only 2x8 Slots (instead of 3x8 - 24 slots) but i guess it's because i don't have cables connected to HSBP from SAS Expander
3. Upgraded to version 02.01.0002. During SDR/FRU update i got following message:
Hot-swap HDD backplane detected but its FRU data is either corrupted or blank.
Falling back to User chassis selection as auto detection not possible
So i selected R2224 as i guessed it's a chassis with 24 disk slots. When it came back after reboot i couldn't find any sensors in RMM but HDD were detected in the first four slots.
4. Upgraded to version 02.06.0005. During SDR/FRU update i got same message as before and same issue - no sensors related to HBSP at all.
5. Downgraded SDR/FRU to version 1.07 and upgrade process detected 2x8 slots.
Do i need to connect remaining ports on the backplane in order to correctly detect chassis type by update process?
Hello Sayetan,
In regards to your question, the SDR/FRU update will keep failing until you connect the rest of the ports on the HSBP.
Sergio S.
stemp2
Hi Sergio,
Thank you for your answer. Ticket can be closed.
Hello Sayetan,
As per your request, I will proceed and close your case.
Sergio S.
