Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4853 Discussions
Broadwell CPU E5-2690v4 related incidents
KChun11
It's grateful that I could find this community. Recently, there were 3 consecutive CPU related incidents in blade servers. The message says "Uncorrectable Machine Check Exception" and "Uncorrectable Memory Error". As a result, it was concluded that Memory Controller inside CPU chipset was the reason.
May I ask if there are Intel Broadwell E5-2690v4 incidents recently reported especially about memory communication?
Thanks in advance.
Hello Ku,
Thank you for contacting Intel support,
I understand that you are having problems with 3 CPUs which have shown error messages, I apologize for any inconvenience this may be causing.
Regarding this problem, I researched about this unit but there does not seem to be any known issues associating the processor in question and those error messages. I apologize for the inconveniences.
David V
Hello Ku,
I am following-up with your case and I see that we have not heard back from you,
Is there anything else I can help you with?
Were you able to solve your issue?
Do not hesitate to reply for further help!
David V
