Please confirm the following bug in latest "Intel® Server Board S2400SC Firmware Update Package for EFI" package.
Details:
version: 02.03.0003
release date: 05/21/2014
link: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23901 Intel® Download Center
in FRUSDR 1.10 utility update package there is a bug that prevents manual setting of Power system unit type when auto detecting fails.
in line 181 in MASTER.CFG
FOUND "PS1_FRU" "PS1_NO_FRU"
should change to
FOUND "PS1_FRU" "NO_PS1_FRU"
and in line 246 in the same file
FOUND "PS2_FRU" "PS2_NO_FRU"
should change to
FOUND "PS2_FRU" "NO_PS2_FRU"
I also checked that this problem also affects at lease one previous update package FRUSDR 1.09
This problem affected my "Intel® Server System R2312SC2SHGR"
thank you in advance
bb
bb,
I am an engineer at Intel, however this is not my area of expertise. Let me get your question to someone who is able to provide you an answer. Due to the holiday it may take a little longer or me to track down a response.
Chris
Hi bb,
You're correct. This is a bug. It will be fixed in Q3'14 release.
Grant
