Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
C226 chipset E3-1265L v4 Iris Pro Graphics P6300
OPavl2
Hello. lspci command does not see integrated IRIS graphic from Linux (Centos7, SystemRescueCD4)
I upgraded BIOS for latest version for S1200V3RPM motherboard for compatibility with E3-1265L v4 processor with Iris Pro Graphics.
Motherboard S1200V3RPM
BIOS: 03.02.0003 (latest)
CPU: E3-1265L v4
But lspci command does not see any Intel Integrated VGA adapter, only embedded Maxtor adapter. BIOS menu also does not show any options for VGA adapter switching.
These hardware are fully compatible http://ark.intel.com/products/88041/Intel-Xeon-Processor-E3-1265L-v4-6M-Cache-2_30-GHz# @compatibility ARK | Intel® Xeon® Processor E3-1265L v4 (6M Cache, 2.30 GHz)
Only one question - what the hell
We strongly recommend contacting our support group directly for further assistance on your inquiry:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Amy_C_Intel
Hello opp1972,
If you have a dedicated graphics card, the card will disable the embedded graphics of the processor it is necessary to get in the BIOS and change the Video settings; enable the processor graphics instead of the graphics card.
Amy.
OPavl2
Hello Amy, thank you for answer.
This motherboard has the embedded graphic card Maxtor and BIOS sees it. No another PCI video not presented.
If I use E3-1226 v3 (third generation), I see "Internal Graphics" in Advanced -> PCI configuration, so I am able to select between "Internal Graphic" or "Onboard Video"
When I insert E3-1265 v4, this item is lost from Advanced -> PCI configuration, and I have only "Onboard Video" from BIOS
Amy_C_Intel
Checking the specifications of your motherboard I noticed that the Intel® Xeon® Processor E3-1226 v3 is not fully compatible to your motherboard, here you can check the compatibility http://ark.intel.com/products/71387/Intel-Server-Board-S1200V3RPM# @compatibility ARK | Intel® Server Board S1200V3RPM, just access the link and click on Compatible Products.
Just keep in mind that you will get graphics either from your dedicated graphics(external card) card or the graphics embedded to the motherboard through. The VGA port is the graphics output built in to the motherboard. Another thing I want to mention is that Internal Graphics and On board Video mean the same.
Amy.
OPavl2
This motherboard has the embedded video Maxtor, and Bios has relevant item - "Onboard Video"
I don't have any question to E3-1226 V3 processor with his internal graphic Intel HD Graphics P4600. Bios has the item "Internal graphics" and I am able enable/disable it.
I don't understand, why Bios item "Internal graphics" is lost, when I am inserting E3-1265L V4 processor. It has internal video - Iris Pro Graphics P6300. This processor is compatible with this motherboard http://ark.intel.com/products/88041/Intel-Xeon-Processor-E3-1265L-v4-6M-Cache-2_30-GHz# @compatibility http://ark.intel.com/products/88041/Intel-Xeon-Processor-E3-1265L-v4-6M-Cache-2_30-GHz# @compatibility and C226 chip is compatible with this graphics. I don't use any dedicated graphics (external card) in my case.
May be E3-1265L V4 has broken internal graphics in my case? I do not have the ability to quickly change the processor or motherboard and check it.
Amy_C_Intel
In order to better assist you we're moving this post to the Servers forum.
Amy.
