Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
CPU Requirements on S5520HC ?
Hi
I consider bying a S5520HC mainbord - and equip it with an E5620 CPU and 2x8GB memory modules....
But searching the web, I found this link: http://www.experts-exchange.com/Hardware/Servers/Q_26266015.html http://www.experts-exchange.com/Hardware/Servers/Q_26266015.html
And I am not quite sure what to mean about it. I would assume, that a single CPU easily would recognize 2 8GB memory modules - and that running a dual-cpu system isn't required for this.
I know that the best thing probably will bee to buy 2 CPU's at once - in order to ensure that they are the same stepping etc.. But the main question is whether it actually is required with 2 CPU's in order to use 2 8 GB modules on the mainboard ?
/Brian
DSilv11
Valued Contributor III
Answer : No
http://download.intel.com/support/motherboards/server/s5520hc/sb/e39529013_s5520hc_s5500hcv_s5520hct_tps_r19.pdf http://download.intel.com/support/motherboards/server/s5520hc/sb/e39529013_s5520hc_s5500hcv_s5520hct_tps_r19.pdf
3.2.1 Processor Population Rules
You must populate processors in sequential order. Therefore, you must populate Processor socket 1 (CPU 1) before processor socket 2 (CPU 2).
When only one processor is installed, it must be in the socket labeled CPU1, which is located near the rear edge of the server board. When a single processor is installed, no terminator is required in the second processor socket.
For optimum performance, when two processors are installed, both must be the identical revision and have the same core voltage and Intel
® QPI/core speed.
Processor sockets are self-contained and autonomous. However, all configurations in the BIOS setup, such as RAS, Error Management, and so forth, are applied commonly across sockets.
HOWEVER, the only DIMMS a single CPU will be able to access are the DIMM in slots A - C (6 DIMMS)
Any memory placed in D-F will not be reconized.
Always use DIMMs off the tested memory list to avoid problems.
http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030221.htm http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030221.htm
DSilv11
Answer : No
® QPI/core speed.
