Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4729 Discussions
Cambiar Velocidad Tarjeta de Red Fibra óptica de un servidor
CSanc8
Hola Tengo un servidor Xeon CPU E5 2630 con Windows Server 2012 R2, le instale una tarjeta de red de fibra óptica X520DA2, necesito comunicarme a 1 Gbps y la tarjeta está programada a 10 Gbps, no he podido bajar la velocidad porque no lo permite, me pueden ayudar con este tema. Gracias
Hi, understand you have concern in setting your X520-DA2 from 10Gbps to 1Gbps, please help to provide information below for us to further understand your issue and setup. Thanks,
1. what is the brand and model of module installed on your X520-DA2?
2. when you mentioned "no permit", does it mean you tried to modify the speed in advanced properties of X520-DA2 in device manager but doesn't have permission to proceed? please share additional information on the error or screenshot if available.
3. if convenient, you may also run the system support utility and share to us the result. Download link of the tool - https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
sharing the website on where you can locate tested module for X520 as reference.
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005528.html http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005528.html
regards,
Vince
