Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
Can I UEFI boot from an NVMe SSD DC P4101 (1.024TB, M.2 80mm PCIe* 3.0 x4, 3D2, TLC) on S2600STB motherboard?
Brendan
Assuming HDDs are controlled by onboard SATA, can I boot from an NVMe SSD in the M.2 slot? Motherboard is S2600STB. SSD is P4101 (1.024TB, M.2 80mm PCIe* 3.0 x4, 3D2, TLC). Thanks.
JoseH_Intel
Hello Brendan,
Thank you for joining the community
It is certainly possible to boot from a NVMw SSD connected in the M.2 slot
M.2 NVMe drives can only boot while on UEFI mode. SATA M.2 drives can boot in either UEFI or legacy modes.
For more detailed info check the Technical Product Specification at section 6.3
Hope this helps
Jose A.
Under Contract to Intel Corporation
JoseH_Intel
Hello Brendan,
Hope this helps
Jose A.
