Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
4329 Discussions
Can I get consultation on compatibility of products directly from Intel ?
AMoha28
I am trying to configure a server for which I have selected following components:
1) Intel Server Board S2600CP2
2) Intel Xeon E5-2620
3) Intel Server Chassis P4308XXMFEN
4) Apart from this, I want to installKingston 16 GB 1.5V ECC Registered DDR3 KVR16R11D4/16I RAM modules on the above mentioned board.
I want to know two things about the above mentioned configuration:
1) if there is a way to speak to someone either from Intel technical support or someonei who can confirm that above mentioned configuration will work perfectly, and
2) if I can purchase the first three items i.e. Intel board, processor and chassis directly from Intel in India ?
Any suggestions or contacts in this regard are welcome.
Akhil
Daniel_O_Intel
You can contact technical support using the options at
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
There should be a local phone number for your area.
Intel does not do direct sales, but there are also links for finding an authorized reseller in your area at
https://www-ssl.intel.com/content/www/us/en/buy/for-home.html https://www-ssl.intel.com/content/www/us/en/buy/for-home.html
