I am trying to configure a server for which I have selected following components:
1) Intel Server Board S2600CP2
2) Intel Xeon E5-2620
3) Intel Server Chassis P4308XXMFEN
4) Apart from this, I want to installKingston 16 GB 1.5V ECC Registered DDR3 KVR16R11D4/16I RAM modules on the above mentioned board.
I want to know two things about the above mentioned configuration:
1) if there is a way to speak to someone either from Intel technical support or someonei who can confirm that above mentioned configuration will work perfectly, and
2) if I can purchase the first three items i.e. Intel board, processor and chassis directly from Intel in India ?
Any suggestions or contacts in this regard are welcome.
Akhil
You can contact technical support using the options at
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
There should be a local phone number for your area.
Intel does not do direct sales, but there are also links for finding an authorized reseller in your area at
https://www-ssl.intel.com/content/www/us/en/buy/for-home.html https://www-ssl.intel.com/content/www/us/en/buy/for-home.html
