Server Products
4917 Discussions
Can Nehalem cut out the need for VMWare in a medium size business?
<!--[if gte mso 9]> Normal 0 21 false false false NL X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <w:LsdExceptio...
Daniel_O_Intel
It looks like you've considered all the important factors.
KAMALANATH_N_Intel
Thanks for your query.but I didnt get the question proper.
R u worried abt the VT pros and cons ?and budget.? anyways i have attached NHM white paper ( may be useful)
please revert with the appropraite question for clear answers.
kamal.
Daniel_O_Intel
No, I would not say I was worried. Virtualization is exactly the trade-off you mention - it is less expensive on hardware, but you are putting all your servers into one infrastructure.
Was that your question? Or are you more looking for someone to tell you "Yes, you should implement this" or "No, you should not"?
