Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4808 Discussions
Compatible replacement for s2600cw motherboard
MSidd2
I am looking for a compatible replacement for end of life s2600cw intel server board.
S2600ST is the new generation server board but the the recommended Socket-P has numerous versions and I am not sure how to select one. I am replacing E5-2600 Xeon processor.
Can you recommend a motherboard and processor?
SergioS_Intel
Hello MSidd2,
Thank you for contacting Intel Customer Support.
I understand that you need a replacement system for your Intel® Server Board S2600CW. We will be more than glad to assist you.
First, we would like to give you some information on the Intel® Xeon® Scalable Processors 3647 socket (Socket P).
https://www.intel.com/content/www/us/en/products/processors/xeon/scalable.html
The previous link is going to give you more detailed information on the different types of Intel® Xeon® Scalable Processors that we have available and this may give a better idea on what replacement processor will fit better for your needs.
Now, upon checking the specs for your Intel® Server Board S2600CW, you can consider the different options that we have available for the Intel® Server Board S2600ST Family and you can find more detailed information here:
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600st.html
For example the Intel® Server Board S2600STBR
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600st/s2600stbr.html
Also, the Intel® Server Board S2600STQR
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600st/s2600stqr.html
Please note that both of the servers listed above will support for two socket 2nd Generation Intel® Xeon® Scalable processors.
I hope the previous information helps.
In case you need more assistance do not hesitate to contact us back.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello MSidd2,
We are following your question and we would like to know if the information that we provided you on the previous post was useful for find a replacement server board for your Intel® Server Board S2600CW.
In case you need further assistance please contact us back.
Sergio S.
SergioS_Intel
Hello MSidd2,
We are following your question and we would like to know if you need further assistance or if we can close this thread.
Sergio S.
MSidd2
I am still trying to replace c2600cw motherboard. There are lot of choices for the CPU.
Can you recommend a new generation intel server board compatible Xeon processors and heat-sinks.
SergioS_Intel
Hello MSidd2,
We appreciate your reply.
You can check these models of server boards that are compatible with the Intel(R) Xeon (R) processors and heat sinks:
Intel® Server Board S2600WFTR
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600wf/s2600wftr.html
Intel® Server Board S2600WF0R
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600wf/s2600wf0r.html
Intel® Server Board S2600WFQR
https://www.intel.com/content/www/us/en/products/servers/server-boards/server-board-s2600wf/s2600wfqr.html
Additionally, you can check the sever boards that we recommended you in our previous post:
Intel® Server Board S2600STBR:
Finally, you can check the specifications of the Intel® Server System S9200WK Product Family this system is compatible with the Intel® Xeon® Platinum 9200 Processors:
https://www.intel.com/content/www/us/en/products/servers/server-chassis-systems/server-board-s9200wk-systems.html
We hope this information helps.
Sergio S.
SergioS_Intel
Hello MSidd2,
We are following your thread and we would like to know if the information that we provided you were useful to answer your question.
Sergio S.
SergioS_Intel
Hello MSidd2,
We are following your thread and we would like to know if you need further assistance or if we can close this thread.
Sergio S.
SergioS_Intel
Hello MSidd2,
We are following up on your thread that is still open with your question about the compatible replacement for the Intel(R) server board S2600CW we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution. Since we have not seen an update for several days, the case will automatically close after 2 business days. You can still re-open the case by replying to this email. Please note that if the case is re-opened more than 15 days after closure, a new thread will be created with a reference to the original case.
Sergio S.
MSidd2
Hi Sergio,
Thanks for the help. I am coming back to this project after the lockdown. I have picked out the intel motherboard:
Intel Server Board S2600STBR - motherboard - SSI EEB - Socket P - C624
Can you recommend a CPU for this motherboard to replace; Xeon E5-2620 64 bit 22nm, 2.4GHz 2011 FCLGA-6cores
Regards.
