Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4462 Discussions
Component Unfit - Message from Intel Modular server
GFrit
The Modular Server MFSYS25V2 (firmware 11.6) leave server modules and find it again after I reinserting. Do you have anybody same problem, and solution for solve it?
The IMS log was:
Action 'Power Off' failure on 'Server 1'Server 1WarningApplicationAction 'Power Off' failure on 'Server 1' by user 'admin', with output of: 'Server 1 failed to power off.The graceful OS shutdown may be in progress. Wait a few minutes to see if the server powers down. If it does not, check the server OS to ensure that it is configured to shutdown gracefully and that it is not preventing graceful shutdown. You may Use the Forced option to force the power off without OS shutdown.'. Warning displayed: 'None.'Fault Indication: Chassis Fault LED OnChassisWarningIPMISensor: Fault Indication; The Chassis Fault LED has been illuminated. This amber LED is located on the front of the chassis and is used to warn of conditions that require attention.Fault Indication: Chassis Mis-configuration Fault LED AssertedChassisWarningIPMISensor: Fault Indication; There is a chassis mis-configuration that is contributing to the chassis fault LED being lit. This amber LED is located on the front of the chassis and is used to warn of conditions that require attention.Chassis Mis-configuration FaultChassisCriticalIPMIA Switch Module is required but not present in Switch Slot 1 contributing to a Chassis Mis-configuration fault.Fault Indication: Chassis Fault LED OnChassisWarningIPMISensor: Fault Indication; The Chassis Fault LED has been illuminated. This amber LED is located on the front of the chassis and is used to warn of conditions that require attention.Fault Indication: ESM 1 Fault LED OnSwitch 1WarningIPMISensor: Fault Indication; The Switch Module 1 Fault LED has been illuminated. This amber LED is located on the faceplate of the switch and is used to warn of conditions that require attention.Action 'Power On' failure on 'Server 3'Server 3WarningApplicationAction 'Power On' failure on 'Server 3' by user 'koltai', with output of: 'Server 3 failed to power on.The server may not be powered on in its current state. Ensure that there are no firmware updates pending or in progress, that no virtualization is in progress, and that there is sufficient power available before trying again.'. Warning displayed: 'None.'Action 'Power On' failure on 'Server 3'Server 3WarningApplicationAction 'Power On' failure on 'Server 3' by user 'koltai', with output of: 'Server 3 failed to power on.The server may not be powered on in its current state. Ensure that there are no firmware updates pending or in progress, that no virtualization is in progress, and that there is sufficient power available before trying again.'. Warning displayed: 'None.'Action 'Power On' failure on 'Server 1'Server 1WarningApplicationAction 'Power On' failure on 'Server 1' by user 'koltai', with output of: 'Server 1 failed to power on.The server may not be powered on in its current state. Ensure that there are no firmware updates pending or in progress, that no virtualization is in progress, and that there is sufficient power available before trying again.'. Warning displayed: 'None.'Action 'Power Off' failure on 'Server 2'Server 2WarningApplicationAction 'Power Off' failure on 'Server 2' by user 'admin', with output of: 'Server 2 failed to power off.The graceful OS shutdown may be in progress. Wait a few minutes to see if the server powers down. If it does not, check the server OS to ensure that it is configured to shutdown gracefully and that it is not preventing graceful shutdown. You may Use the Forced option to force the power off without OS shutdown.'. Warning displayed: 'None.'Component UnfitServer 2CriticalSystemComponent Error. Try removing and reinserting component. If this does not resolve the issue the hardware may be defective.Component UnfitServer 2CriticalSystemComponent Error. Try removing and reinserting component. If this does not resolve the issue the hardware may be defective.Component UnfitServer 1CriticalSystemComponent Error. Try removing and reinserting component. If this does not resolve the issue the hardware may be defective.
Edward_Z_Intel
See if this helps: http://www.intel.com/support/motherboards/server/sb/CS-030708.htm http://www.intel.com/support/motherboards/server/sb/CS-030708.htm
In your case, it seems to me the switch module has some error, and that may cause Component Unfit error on other components.
Edward_Z_Intel
