all of the sudden the Modular Server Control shows for both blades that are installed "Component unfit". I have reinserted both blades allready and restarted the whole CMM. I even installed the latest Firmware (6.10) to resolv that problem, but I did not change anything either. The blades are still working properly, but due to that massage I do not get any further option in Modular Server Control, e.g. remote KVM, shutting down etc. What else can I do to fix that issue?
Fini
There are a few other things to try at http://www.intel.com/support/motherboards/server/sb/CS-030708.htm Intel� Modular Server Systems — Error: Component unfit - do you have two Ethernet Switch Modules installed, or just one?
there are 2 modules installed. But what do they have to do with the compute units? One switch is not used at all at the moment.
If you have two switch modules installed, the most common cause is admin link.
From the CMM GUI, choose System | Switches | Advanced Configuration
Mouse over any port and choose Port Configuration
Select Port | 10G.XC | Admin Status - if it is not already set for Down, set it for Down. Do the same thing for
Port | 10G.SC | Admin Status | Down
