Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4482 Discussions
Configuring Intel ® Remote Management Module 4 on one NIC port 1
AKvas1
Hello
Help me, please.
I have a server with RMM4.
Server is connected to only one port to the NIC 1.
There is a network setup:
ip: 78.24.218.163
Subnet mask: 255.255.248.0
Gateway: 78.24.223.254
How do I make a single port (NIC 1) worked RMM4 and operating system?
Thank you.
Edward_Z_Intel
The BMC LAN channel 1 and OS NIC1 have different MAC addresses, although they share the same physical connector. So what you need to do is assign a different IP address for the NIC in the OS.
Edward_Z_Intel
DSilv11
Valued Contributor III
Go into BIOS set up (F2 during POST)
Select Server Management - BMC Lan Configuration
Fill in the IP infor in the section labeled Baseboard LAN configuration.
On the bottom of the same page, make sure you have configured a User Accout.
I usually select
User ID User 3
Privilage Administrator
User Status Enabled
User Name Doc_SilverCreek
User Password ***********
Then press F10 and save.
You should now be able to open a web browser from any system on the same network to http:\\78.24.218.163
AKvas1
Thank you all. Reply Edward @ Intel is what I need.
