Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
D945GSEJT and sensors
I have a small server based on a D945GSEJT board which is running Ubuntu 10.04LTS. I would like to be able to monitor the server hardware. To do that I have loaded successfully the coretemp and w83627 kernel modules and indeed the sensors command produces an output. Some of the output is easy to interpret (the system has no fans so ignore that and it does not have a temp3 sensor so ignore that too). What I am a looking for is the interpretation of the voltages that come out of the default sensor command:
w83627dhg-isa-0a00
Adapter: ISA adapter
Vcore: +0.86 V (min = +0.00 V, max = +1.74 V)
in1: +1.58 V (min = +0.28 V, max = +1.65 V)
AVCC: +3.39 V (min = +2.98 V, max = +3.63 V)
in4: +1.89 V (min = +1.18 V, max = +0.65 V) ALARM
in5: +1.22 V (min = +0.26 V, max = +1.13 V) ALARM
in6: +1.59 V (min = +0.43 V, max = +0.60 V) ALARM
3VSB: +3.42 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.33 V (min = +2.70 V, max = +3.30 V) ALARM
fan1: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan2: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan3: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan4: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
temp1: +44.0°C (high = -58.0°C, hyst = +64.0°C) sensor = diode
temp2: +58.5°C (high = +80.0°C, hyst = +75.0°C) sensor = diode
temp3: +127.0°C (high = +80.0°C, hyst = +75.0°C) ALARM sensor = thermistor
cpu0_vid: +2.050 V
I have looked all over for a description of the voltages using the W83627 chip on this board but alas every motherboard manufacturer can and does his own thing. Therefore configs for Supermicro boards don't seem to make much sense for the intel board and vice versa. Also, there is no descrption in the board's manual of the different voltages measurements. Nor have I been able to find anything on the intel web sites. Anyone have any idea of what in especially in1, in4, in5 and in6 are? For instance, I would expect at least one of them to be the 12V input.
Tags (1)
Highlighted
Here's the information for D945GSEJT:
Input Voltage Multiplier Necessary
VIN1 +5V 3.2
VIN2 +12V 6.6
VIN3 +3.3V 2.8
VIN4 +5V Standby 3.2
If you don't get much reply from the server communities, you can also try the desktop community over at http://communities.intel.com/community/tech/desktop http://communities.intel.com/community/tech/desktop
Highlighted
Community Manager
Problem has been solved. I have a config file for the sensors now that make sense.
Many Thanks
Highlighted
Community Manager
Any chance you could share the config file?
Many thanks
Highlighted
Community Manager
Hi, it would be really helpful if you can share the config file.
Thanks in advance,
Stefano
