Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5058 Discussions
DELL PowerEdge M620 with Intel Ethernet 2P 10G x520-k bNDC
hi all,
im new here..
I have an issue with NLB using this ethernet card. Im not using Virtual but Physical blade server. when i try to create NLB using windows Load Balancing over Unicast Mode, IP on this Ethernet Card suddenly disappear. i'm try to check over command prompt using "ipconfig" command, the information about IP address, Mac address and the other also disappear. I try to update the driver into the latest one, but got no luck.
does anyone here know what should i do with this case ? operating system is using Windows Server 2008 R2 SP1
castr
