Server Products
4784 Discussions
DP35DP Ethernet Driver OK button unresponsive
MMart43
Hi All
I inherited a clunker of a server which I am slowly decommissioning, but due to a 3rd party software problem I was forced to do some change diagnostics.
This DP35DP machine running Windows Server 2003 x86 had an old ethernet driver for the onboard controller installed, reporting as a 82566DC. So since there were no official Windows 2003 driver for the motherboard, I decided to search and download from the 82566DC resource page and update it to see if it resolved my other problem.
The latest available driver 18.3 installed OK with no issue and my network is running, but I noticed I could not click the OK button on the properties page to accept changes. Fortunately the default settings are fine for me.
Is there somewhere I can get an earlier driver, since there is only the "latest" listed for me?
Is what I've done a bad thing? There is a 15.3 driver for XP from the DP35DP motherboard page, will this work and is a better choice to try? Or should I just leave the Windows supplied driver?
Thanks for your advice
Marty
Allan_J_Intel1
Thanks for joining the Desktop Board community.
I understand you are looking for Windows server 2003 drivers for LAN adapter.
Please bear in mind that Intel does not keep track of older driver versions, you may want to check for Win2003 Server drivers at the link below:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18719 Intel® Download Center
You may try this link if you need different versions:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Network+Adapter+Drivers+for+Windows+Server https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Network+Adapter+Drivers+for+Windows+Server
Allan.
MMart43
Thanks Allan,
I see in the second link there is a 16.7 driver for onboard controllers, and while it doesn't specifically mention the DP35DP, it does have the generic title of Gigabit controllers so I am sure this is a more appropriate driver. I will try it out and if all else fails go roll back to the original driver (which was probably the Microsoft supplied driver).
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18388 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18388
Marty
