I’m currently working on a system that leverages Intel DSA’s `cr_delta` operation.
I’ve observed the following behavior across different generations:
- On **Sapphire Rapids (SPR)**: the `cr_delta` operation works as expected.
- On **Emerald Rapids (EMR)** and **Granite Rapids (GNR)**: attempting to use `cr_delta` results in an "unsupported opcode" error (error code `0x10`).
This suggests that the delta-related opcodes may no longer be supported in EMR/GNR.
However, I couldn’t find any documentation explicitly stating whether these instructions have been deprecated or disabled in newer microarchitectures.
Could anyone clarify:
- Whether `cr_delta` and other delta-related operations are officially supported in EMR/GNR?
- Are there any platform or firmware flags that need to be enabled?
Thanks in advance for your help.
