Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4835 Discussions
Device Passthrough across Sockets in a Multi-Socket Setting
agule
Greetings,
In a Dual Socket Server is it possible to passthrough a "PCIe device A" which is hanging from Root Complex of CPU 1 to a VM that is pinned on CPU 2. If so is there some PCIe/QPI(or UPI) Packet encapsulation/decapsulation that takes place ?
P.S. I don't have access to a dual socket machine so can't test it myself.
Hello mailto:anubhavg@iisc.ac.in anubhavg@iisc.ac.in,
Regarding your question, "Device Passthrough across Sockets in a Multi-Socket Setting".
But to better help you, could you please help me with some additional information.
Type of PCI cards you are using
The version on VM or ESXi been used.
CPU.
System board.
Thank you for your time and help.
Henry A
I just will like to follow up on your threat "Device Passthrough across Sockets in a Multi-Socket Setting".
Wanted to double check if you had the opportunity to provide us with the information requested:
CPU.
System board.
Henry A
agule
Thanks for the response.
I don't have a dual socket server to test this thing. It was just a doubt that whether it is doable.
And if so is there some PCIe/QPI(or UPI) Packet encapsulation/decapsulation that takes place ?
No problem at all, lots of question on the Forums, normally can be related to something you might want to work on the future.
But for the PCIe/QPI(or UPI) Packet encapsulation/decapsulation. First, it will depend on the motherboard manufacturer and the OS been used.
If there any other questions, I will request your permission to close the threat.
Henry A
agule
Thank you for your time and have an excellent weekend.
Henry A
