Hi all.
I having server motherboard S3200SHV which placed in Ascot case (not Intel ).
I upgrade BIOS, FRU, SDR & BMC and after this fans stopped. Next i again run frusdr.nsh, my steps:
1. Other chassis.
2. Case intrusion - n.
3. CPU 1 fan - y.
4. System fan 1 - y.
5. System fan 2 - y.
6. System fan 3 & 4 - n.
No affect. I try most possible combination chassis, fans, move fans into SYS_FAN 3 & 4 connectors - nothing not helped.
What is this? Can i break 2 fans immediately?
All the fans stop? Even the CPU fans? I don't think the power supply is doing its job.
What if you just say "yes" to all fans installed - can it run that way, even at full speed?
CPU Fan 1 work normally.
Did not work SYS_FAN1 & SYS_FAN2. I connected them in SYS_FAN3 & SYS_FAN4 - in this connectors fan also not work. Hey! Need test fans - putting they in CPU connector and test. I do it today.
